Ricko
Ricko
Ricko
6,755
Member
10,565
Birthday
February 7, 1977
merlo san luis argentina
Mapmaker
22
  • Mistery in the Inn
    Cheers
    LoopysueMonsenGeorgeRalfQuentenGlitchJimPEukalyptusNowroflo1Lautiand 2 others.
  • Escobar Mansion A0
    Cheers
    Loopysueroflo1DaltonSpenceQuentenMapjunkieMonsenGlitchJimPFersusCalibreand 7 others.
  • A bridge II
    Hy @EukalyptusNow !
    The cliffs were not reversed. I just maximized their size. I also have a lot of problems with them, because they look very "hard" visually. I miss the Mike Schlei style of negative cliffs, like someone looking from the bottom up.
    As for the extensions of the bridge, I used the tree trunk from the monthly lumberjack symbol > tree trunk without branches. I hid it in the back after the bridge was already made... so I needed to create a specific Sheet for it. Later, I tried to hide the joints with some vegetation.
    Also note that on the bridge, I created a sheet just to put some sand on top and give it a more "used" look and notice that on the green sheet of the upper greens, I added an internal glow with a brownish color to differentiate it from the floor below (river) and try to achieve the effect of a ravine.
    P.s.: Lower Cliff lines are imported from Sue Richards Darkland Style
    Cheers
  • A bridge II
    Cheers
    LoopysueMonsenJeff BScottAQuentenEukalyptusNowWeathermanSwedenGlitchMapjunkieDaltonSpenceand 4 others.
  • A bridge
    LoopysueJimPQuentenScottAJulianDracosMonsenroflo1RalfEukalyptusNowadelia hernandezand 6 others.
