Ricko
Ricko
Ricko
6,089
Member
10,022
Birthday
February 7, 1977
merlo san luis argentina
Mapmaker
  • Mixing Mike Schley isometric city + Mike Schley Overland symbols
    11 - to import, right-click and CC3 navigation will open (I don't know the correct term for that part)
    12 - Back to symbols, from there MAPS (overland) > MIKE SCHLEY COLOR
    13 - In the mike schley color folder (overland) I go, subfolder by subfolder choosing the icons that I like the most. Detail here: I prefer to start with the trees, I import all the trees I want to work with, and then I go to the city's vegetation and also click on all the trees I want. In order for the program to record all the multi options (when they exist) in the icon groups, at this point I hit TAB so that they all appear, then I move to the next icon. I select all the trees I want and group them.
    14 - I keep choosing icons from other folders (preferably all together - Mountains and hills, structures, natural etc. Folder by Folder.
    Once I've imported everything I want, clicking on that part will show you all the imported items (save your work now). Earlier I mentioned that I like to import in sets (whether it's just overland or in the example of trees, overland + isometric trees) and the reason for this is to facilitate the workflow, since things will be in that part, grouped in similar: trees, buildings, mountains and hills, structures, etc.I start with the river
    15 - I start with the river
    16 - I notice that it is too thin and I want it to be bigger (its measurement is in 2)
    change properties and put size 6 (3 times the original)
    17 - refresh and seems ok to me, lets go
    18 - Note that the isometric city recognizes mike schley overland trees as when you work with overland. as SYMBOLS TREES and, as it did not exist before - the program creates a new sheet with that name by itself. Move it under (on top) of the sheet symbols.
    SYMBOLS TREES new sheet is in correct place now..
    19 - Having the tree symbols you want all together helps especially when you're looking for "vegetation diversity" making work much faster. Choose the trees you want but keep in mind that some of the icons come in "different size scales" be aware of this difference and solve it by pressing CTRL and moving the mouse up or down. As a tip, also vary your sizes intentionally, so you have a greater variety of looks.
    20 - once the trees are in place, I go to the buildings. Note that I will stick to the SYMBOLS TREES sheet because at this point if I go back to the symbols sheet, the images I will use will be behind the trees.
    with all the icons, trees, structures etc, sometimes I use the mirror function: I select an icon, left-click and click mirror. Doing this allows for variety, especially in the most interesting constructions, and will have a less monotonous final result.
    MonsenScottAjmabbottWeathermanSwedenMapjunkieJuanpi
  • A Village
  • A Village
    Cheers
    roflo1LoopysueRalfGlitchkevbeck43MonsenMapjunkieJimPWeathermanSwedendragarhirand 4 others.
  • Suggestion annual 2023
    some more variations
    roflo1mike robelmacdanny
  • Elven City
    Colors processed in Lightroom.
    Cheers
    MonsenJimPLoopysueGlitchTheschabiDakroflo1Ralfmacdannykevbeck43and 6 others.
