Ricko
Ricko
- Ricko
- 6,750
- Member
- 10,565
- February 7, 1977
- merlo san luis argentina
- Mapmaker
- 22
Reactions
[WIP] Spectrum Overland Waterfalls x 2
Sometimes, it is possible to make lakes and waterways with a little patience when fitting images of hills and mountains.
Spectrum Overland has sharper and more interesting shadows than Mike Schley for example, but on the other hand, it is very difficult to invert the images to have more possibilities of varying the scenery.
Hy Royal! Achieving depth of field with assets designed for a longer view can be tricky. One of the techniques I usually use to try to achieve this effect is to "strip by strip" progressively increase the size of some - but not all - icons.
In this example, while I use smaller and smaller hills as they get closer to the observer, the trees instead gradually grow larger to create a greater sense of proximity and distance. In the case of this style, all the images go to the default Symbols, since there is no specific sheet for trees, like Mike Schley for example.
In this case, as sometimes with Mike Schley, I have to put "everything on the same sheet" (in the case of Mike Schley I use all or most of the drawing on the TREES sheet) and go drawing layer by layer. It is always advisable to have a draft or sheet trace image with a very clear base transparency before starting, so as not to waste time and to make the task easier.
If you want to add even more realism to these scenes, gently vary the size and types between trees "in the same tree range". I usually do this visually with the controller, checking every so often to see if it is within the acceptable size range for that location.
The Lands of Strauvuvrorr
Less Lines on Edge Stripe @Monsen
