Ricko
Ricko
Ricko
6,731
Member
10,564
Birthday
February 7, 1977
merlo san luis argentina
Mapmaker
22
  • [WIP] Applevale
    To add more depth to the image, I suggest considering establishing 3 or 4 regions in the image (at least I usually do this) where the icons change size, each time a little larger.
    To avoid getting lost, I usually leave an example of the size outside the map as a reference if I need to go back to work on a previous area.
    Royal ScribeQuentenMapjunkieGlitchJuanpiLoopysueRyan Thomas
  • Map for a friend part 34536....
    After some tweaks with the storyteller, here is the final result.
    LoopysueRyan ThomasRoyal ScribeTheIneffableCheeseMonsen
    This time a new map for my friend to master for his two daughters (8 and 6 years old) and his 9 year old niece. This time he asked me not to put names, as the names will be jointly created by his mini players.
    Cheers
    Royal ScribeLoopysueQuentenKertDawgMapjunkieRyan Thomas
  • Volcanoes
    Last in the collection, I decided to try something with a "psychedelic" touch of saturated colors and the Overland Vector Color palette turned out to be very good for that.
    MonsenLoopysueRoyal ScribeRyan ThomasQuentenMapjunkieJuanpi
  • Volcanoes
    This annual doesn't directly a volcano image, but by gently altering the image on the X and Y axes, I was able to give it a reasonably similar appearance to an inactive volcano.
    QuentenMonsenRoyal ScribeRyan ThomasMapjunkieJuanpi
