Ricko
Ricko
Ricko
6,725
Member
10,560
Birthday
February 7, 1977
merlo san luis argentina
Mapmaker
22
  • [WIP] Applevale
    In this small example, I've separated them into even more sizes, adding an extra, even larger, fifth line.
    Note a small detail: in topic 2, among the standard-size trees, there are some smaller trees. Compared to the others, where only the standard size is present, it gives a more "organic" and realistic appearance, at least to me.
    Trees behind and in front of the hills also contribute to a more harmonious view.
    QuentenMapjunkieMaidhc O CasainJuanpiLoopysueRyan Thomas
  • [WIP] Applevale
    To add more depth to the image, I suggest considering establishing 3 or 4 regions in the image (at least I usually do this) where the icons change size, each time a little larger.
    To avoid getting lost, I usually leave an example of the size outside the map as a reference if I need to go back to work on a previous area.
    Royal ScribeQuentenMapjunkieGlitchJuanpiLoopysueRyan Thomas
  • Volcanoes
    On the other hand, if you don't post either, we can't give you any useful advice to improve them further.
    In my case, I can only help with the visual aesthetics and proportions within the frame. I know very little about operating the software, lol.
    Ryan Thomas
  • Compass Roses
    Where are the compass roses for dogs and cats? 🙄
    Monsen
  • Hex Crawl Test
    Some Cartouche options for the ("empty") corners outside the Hex Center could also be a good addition to the style.
    C.C. Charron
