Ricko
Ricko
Ricko
6,726
Member
10,561
Birthday
February 7, 1977
merlo san luis argentina
Mapmaker
22
  • Fast Marshes Tutorial
    9-now the little secret.
    as the fill style of this drawing is not ocean, I can move Sheet Ocean below sheet Land (easier). In case you have Ocean as the base of your initial Fill Style, no problem, Create a SHEET SEA LAKE/MARSH/POOL etc and move that sheet below Sea (original) and LAND, and work on it.
    Sometimes the same thing happens when CC3 switches to SEA normal instead of SEA LAKE, as in the previous example of SYMBOLS TREES.
    LoopysueLauti
    6 - Create SYMBOLS TREES GRASS sheet, and place it above SYMBOLS BACK sheet. Select this sheet to work with and choose Scrub icon (grass).
    VERIFY if CC3 keeps the SYMBOLS TREES GRASS sheet or if it simply switches - it happens a lot to me - to the SYMBOLS TREES Sheet. In case of change, Select SYMBOLS TREES GRASS again
    LoopysueLautiJuanpi
  • working fast - kinda tutorial
    17 - Always Have the Rule of Thirds in mind.
    LoopysueMonsenGlitchLizzy_MaracujaMapjunkiepablo gonzalez
    14 - Because they are on the SYMBOLS sheet, once I refresh the drawing, they are automatically behind the trees (SYMBOLS TREES), in case you want the same effect behind, you will have to create a SHEET SYMBOLS hills/dune back and place it below from Symbols BACK and above Symbols trees back. That way they will also automatically go to the right place, under the trees behind.
    LoopysueLizzy_Maracujapablo gonzalez
    13 - to add more colors to the drawing, select dunes and a different color, in this case I chose brown 36 (I believe), put them on the SYMBOLS sheet and choose their places quickly.
    Loopysuepablo gonzalez
