Royal Scribe
Royal Scribe
Royal Scribe
9,534
Member
3,353
Birthday
February 5, 1968
San Francisco, California
Website
Real Name
Kevin
Mapmaker
16
  • [WIP] Temple of Fah (May Annual: Stairs and Steps)
    I've been playing around with Wyvern's great suggestions.
    I tried to give the ziggurat a more weathered look by using the FRACTALIZE command. The default settings were way off but I played with it enough to think that with time, I could get it to look right. The problem was that I tried it on a single layer of the temple, and even with just that single layer, it added so many nodes that it slowed everything way down -- and that was just the first of eighteen levels of the temple! So I think my temple won't look weathered after all. Maybe the gods are preserving it. ;-)
    Then I hid the desert symbols so that I could play with the different textures and effects to create the illusion of dunes. The Dungeons of Schley style has five sand fills (with 1 being the lightest) and five corresponding partially transparent textures to overlay. The main background in my map was the middle one, Sand 3_SS4. Over the entire map, I also added the Sand 2 T_SS4 texture on a sheet called SAND TEXTURE 1 BASE, which has an inner edge fade to soften it. I then added another sheet called SAND TEXTURE 2 PATCHES, where I drew patches of the textures 1, 4, and 5 (2 already applied to everything, and 3 being the same as the main sand).
    For the dunes, I added another sheet, SAND TEXTURE 3 DUNES. It has three effects: Edge Fade, Inner; Bevel, Lighted; and Blur. I then added dunes, trying with first the Solid 10 fill and then some of the sand ones -- but actually, I kinda think the Sand 3 blends in best.
    Here's how it looks:
    Here's my Bevel settings:
    And here's the FCW:
    Thoughts? More dunes? More sand patches? More anything else?
    As an aside, learning these desert techniques is very helpful. Last November, one of the first maps I attempted was a Blue Dragon's desert lair. I abandoned it, but I've learned so much in the last six months -- time to revisit it!
    LoopysueWyvernRalfCalibre
    Made some tweaks, particularly to the desert in the northwest corner. I added a TERRAIN SYMBOLS sheet of cracked seaflats. Over that, I did a second TERRAIN SYMBOLS 2 sheet for the sands symbol. And then finally, a third TERRAIN SYMBOLS 3 sheet for scattered dunes.
    Also addressed the dimples in the temple by adding a layer of the gold foil for each level of the ziggurat. I probably won't add more color key "etchings in gold," but I had to add something, and now I'm all set if I do want more.
    And recommendations?
    MapjunkieLoopysueRalfRickoShessarWyvernGlitchJuanpiDak
    I was playing with the Stairs & Steps annual, and (inspired by a recent episode of The Amazing Race, which I'm finally getting caught up on), I started to design something inspired by the steps of El Peñón de Guatapé in Colombia. I ended up gravitating to Marine Dungeons to do it in, but for my first foray into using Stairs & Steps, I wanted to start with something in the Mike Schley style.
    One of the human cultures in my campaign world is a desert culture with a religion loosely inspired by Egyptian mythology. (They also have a militaristic government where powerful noble houses sponsor warriors who fight in grand competitions every four years to accrue points used to determine the number of seats each noble house has in the ruling council. I came up with the idea 40 years ago when I first watched the Olympics on television, and the idea keeps coming back every four years.)
    Anyway, their religious temples are in the form of pyramids and ziggurats, and the latest Stairs & Steps annual gave me the impetus to create a ziggurat in the desert. This is designed in SS4 Dungeons of Schley, with bits of SS5 Cities and Schley and SS3 Mike Schley Overland thrown in.
    I am seeking aesthetic input on a few things:
    1. For the desert terrain, I chose a sandy background as the default and added a layer of a sandy texture over it. But I have also been playing with the cracked seaflats, sand symbols, and dunes symbols. Thoughts on what works?
    2. I thought maybe putting the cracked seaflats around the border of the Ziggurat and then some dunes near the borders of the map. (One of the images I'm embedding zooms on some examples.) Should I put the sand symbol through? Just on the northwestern part away from the buildings? Not at all? I always triple-guess my aesthetic choices.
    3. Inspired by the bronze inlays in Marine Dungeons, I wanted to do something similar on the top of the ziggurat. I created a crude inlay representing the sun, but then used the goldleaf texture from Sue's Parchments. Do you think that works, or should I instead use the bronze texture from Marine Dungeons?
    Here is the full map to date, with a few zoomed-in images to illustrate my questions. (Oh, I am aware of the pock-marks in the temple. I plan to put a layer of a dark gray color or maybe the goldleaf fill below each level of the ziggurat to fix that. But part of me wonders if the pock-marks actually make the ziggurat look weathered?)
    C.C. CharronQuentenLoopysueMonsenAleDGlitchJuanpiDak
  • MY MUNDI IS READY!
    These are great. I really like how you scaled up the dunes in the Mamede map. It's giving me Lawrence of Arabia vibes!
    Ricko
  • I designed crenellation symbols
    In a recent thread, @Traveller mentioned that he is seeking to discover the best style of designing castles in order to map the many real castles of the U.K.
    I have been on a similar quest, though my quest is so that I can design fantastical castles of folklore and fairy tales, like Camelot and Sleeping Beauty's Castle, or the castles in Errol Flynn movies. Castles with many levels of battlements, parapets, towers and turrets, gardens with hedge mazes, and imposing keeps.
    One of the things that seems to come up regularly in these forums is crenellations. I was experimenting using Mike Schley's walls along the top edges of my fortresses, and that looked okay, but didn't allow for much flexibility since the symbols come in one length and the wall drawing tool doesn't show the embrasures and merlons.
    Anyway, I designed some symbols. I have 5' x 5' square ones. I have trapezoidal ones that can be placed to have arrow slits. I have corner L-shaped pieces. And I have several different rounded ones for round towers, including a tapered one to create arrow slits.
    They are all created using CC3+'s drawing tools, with fills from SS4 Dungeons of Schley. There are five different shades of every shape, using Mike Schley's Natural Stone 1 through Natural Stone 5. (This was designed in SS5 Cities of Schley, but I imported the Dungeons of Schley fills as well.) I think that approach allows them to be used in the Atlas. @Monsen, can you confirm?
    (I used the Stone Paving Grey for the structures, but tried one tower with Stone Paving Brown to see how it would look. The intention was to try to create the look of
    They are all designed for a five-foot wide crenellation -- basically, you'd draw a line or circle with a 5-foot width for the base of the crenellation and then place the merlons on top. I've tried it both placing them by hand and also using SYMBOLS ALONG, and both approaches work reasonably well.
    I am not an artist, and I'm sure others here could do much better ones, but I think it gets the job done. I'm happy to share if anyone would like to use them.
    Here is the FSC file and also an FCW example:
    And here are some images so you can see how they look. (I put a Bevel effect on the merlons, which is showing some odd effects because the colors with the base are close, even though I used a darker shade of the Natural Stone for the base.)
    Here's a close-up of the trapezoid merlons along the edge of a straight building.
    And here's one using the trapezoidal merlons for the lower level and then the square ones for the higher level. It also shows the corner pieces.
    Here are two different round towers. The one on the left has normal merlons, and the one on the right has tapered ones for arrow slits. (I need to fix the Wall Shadow effects -- the base of the tower should not be casting a shadow farther out than the crenellation on top of the tower!)
    Here's a quick "proof of concept" of a multi-level castle with different crenellation styles, plus some domes from City Domes for turrets.
    And one last tower using the brown paving fill. This one uses a wider merlon using the SYMBOLS ALONG tool, but I don't think it's quite lining up correctly.
    Feedback welcome, and feel free to use the FSC if you like them.
    LoopysueCalibreroflo1QuentenTravellerGlitchMaidhc O CasainWyvernC.C. CharronMapjunkieand 1 other.
