Royal Scribe
Royal Scribe
Royal Scribe
9,535
Member
3,353
Birthday
February 5, 1968
San Francisco, California
Website
Real Name
Kevin
Mapmaker
16
  • floathing Island and Babel Tower style city
    Very cool!
    fil
  • [WIP] Temple of Fah (May Annual: Stairs and Steps)
    I tried the color key to nibble away at the textures, and it worked. But even better (and more obvious): I could, and did, add additional sandy patches to fill out the...fill.
    But the color key suggestion gave me the idea of using it to nibble away at the temple itself, creating missing chunks (with magenta fractal polygons) and cracks (with a magenta fractal lines). I hope I didn't overdo it, but the nice thing about using the color key approach is that it's a lot easier to remove some of them than it would be to fix moving nodes around, for example.
    I had already placed a gold inlay beneath each layer of the temple, but other than the very top, I didn't need it to be gold. I tried changing them to the Solid 10 and Solid 20 fills, but that allowed the pockmarks to return. So I changed it to a brown color and then added a gray inner glow.
    If nothing else, the erosion takes your eye away from places where I missed fixing the repeating patterns of the texture.
    QuentenLoopysueMonsenGlitchseycyrusWyvernroflo1Dak
  • EUREKA MOMENT: CA15 Heraldic Symbols as CA180 Marine Dungeons 2 Brass Inlays
    I just had an epiphany -- one that may be obvious to most of you but has tickled me to pieces.
    Ever since I saw Ralf's two video demos of Marine Dungeons of using the brass inlays (which prompted me to immediately purchase the 2021 Annual), I have been obsessed with putting in brass inlays wherever I can get away with it. I even did one in my recent Sun God temple which was in a Mike Schley style, only I used a goldleaf background from Sue's Parchments with a crude, hand drawn depiction of the sun.
    I have wanted to do more inlays in everything, but I am not an artist. But it suddenly occurred to me: Sue's inlays are vector images, and CA15 Heraldic Symbols (from Annual Volume 2, 2008) are vector images, and some of those vector symbols are varicolor....
    So I experimented, and it worked! Upper left is one of the vector images from Marine Dungeons, just as an example of how it's supposed to work. Upper right is a dolphin symbol from Heraldic Symbols that intentionally keeps the black outline, as does the fleur-de-lys crest in the lower left. The lion intentionally omits the black border.
    There aren't a ton of symbols in Heraldic Symbols, and fewer still that are varicolor, but the cool thing is: if you use CA15 Heraldic Symbols to design a coat of arms, and use the varicolor symbols set to the magenta #6, you can then have the coat of arms engraved in brass at the base of the dais in your throne room. Just copy the crest into your map and move it to the floor sheet after placing the brass inlay fill on a sheet directly behind the floor (adding the color key effect to the floor if your map doesn't already have that).
    LoopysueMonsenRickoC.C. Charronroflo1QuentenRalfGlitchDaltonSpenceTheschabiand 5 others.
  • [WIP] Marine Dungeons Lighthouse (more May Annual Stairs & Steps)
    Added a few final touches (a friend was confused about the seaweed washed up on the beach, so I added a little more floating in the sea, and a few other minor tweaks here and there. Not really sure what that line cutting off the light in the nighttime version is from.
    Here's the "final" (is anything ever really final?) version of the daytime and nighttime full maps. More details maps in my galleries.
    QuentenLoopysueMonsenRalfGlitchDaltonSpenceJuanpi
  • Tutorial - Between hills, rivers and trees
    Yes, thank you! I've seen the first one before but it's handy to have the tutorials all in one thread. Much appreciated!
    Ricko
