Royal Scribe
Royal Scribe
Royal Scribe
9,532
Member
3,353
Birthday
February 5, 1968
San Francisco, California
Website
Real Name
Kevin
Mapmaker
16
  • [WIP] Rise of the Crone-Mother
    Here's the above-ground areas of the Frostmaidens' Cradle, lair of the alpine hags. The underground areas will make use of the Ice Caverns annual.
    RalfLoopysueQuentenRyan ThomasRickoMapjunkieGlitch
    I also drew in shadows beneath the elevated huts so that I could create battlemaps with the houses hidden, for combat underneath the houses. (They're supposed to be about 10 feet off the ground.) I was going to use tree stumps as the poles supporting the houses, but the Marine Dungeons columns were right there and I do love them -- and there are versions that conveniently already have the ripple effect added for the huts that overhang the water..
    QuentenMonsenTravellerLoopysueRickoRyan ThomasGlitch
    More progress on the swampy lair. Here with trees shown and the treetops hidden. (With the latter, you can see the ripples around the trunks of the trees in the water -- I do love that ripple drawing tool so much!
    Also added more algae throughout. In the southeastern island, I added a pool of blood where the hags conduct their gruesome rituals. And to the northeast of that island, there's a pen where the hags and their lycanthropic were-crocodiles breed crocodiles.
    MonsenLoopysueRyan Thomas
    Working on the Swamp Hags' lair now.
    A year ago for Halloween, I did a series of maps experimenting with creating a swamp witch's lair using three styles: Dungeons of Schley, Marine Dungeons, and Forest Trail. Of the three, Marine Dungeons was my favorite. This time, I decided to experiment with using Darklands City, because I love the green hue of the water effects. I wasn't happy with how it was turning out, so I experimented with using Creepy Crypts, with some of the sheet effects on Darkland City's water brought over.
    But I still wasn't happy, so I went back to Marine Dungeons. Last time I used Marine Dungeons for a swamp, I had to play with the sheet effects on the water to give it a swampy vibe. This time, I discovered right away that simply changing the background from the lovely tropical beach sand to a more muddy earth color immediately changes the water, too. This doesn't change any of the sheet effects, it just changes the background from Marine Dungeon's sand to the CA181 Dirt 03 from Forest Trail.
    This also makes use of symbols and effects from Creepy Crypts, Forest Trail, and Darklands City (plus tentacles from Sinister Sewers because I wanted the green tentacles). This is a battlemap view with the treetops hidden so you can battle beneath the branches.
    This is still a work in progress. Among other things, I need to add tons more trees on the land and in the water, plus more dirt and vegetation patches. And lots more algae.
    There are three hags in the swamp hags' coven. Each has her own thatch cottage elevated on pillars, and then the slightly larger thatched cottage in the southeastern side is their ritual room. The hags use ladders to get into their private quarters, but the ritual room also has stone steps descending into the swamp water. You can also see the bone bridge connecting this area to the teleportation portal.
    Here's the teleportation portal (from Creepy Crypts). I was going to add the glow symbol from DD3 but the effect wasn't as subtle as I wanted, so I drew a purple polygon on a sheet with an inner edge fade that goes from 0% opacity at the edges to 40% in the center. I may redraw it with a longer radius. (The purplish dots are will-o'-wisps.)
    And here are the "prisons" for the hags' captives. Muddy pits contained by low walls (about one foot off the ground) where victims are submerged halfway up their chests. The tentacles keep them restrained and also fight off rescuers, but their suctions also administer a low-dose poison that keeps the captives asleep most of the time.
    QuentenLoopysueRickoMonsenRyan Thomas
    Here's the inside of ones of the hag's caves. Outside, you'll see her cauldron over a fire pit along with some gruesome trophies: skulls and scalps on pikes. (Also added bed a of fungi outside). Bones dumped in a heap in the opening area. "Bedroom" area off to the left -- the bed is just a pile of dried leaves. Some cells for captives (fresh meat!) with grasping vines to keep captives "shackled" and carnivorous roots barricading the doorways. And in the middle, steps going down...
    Oh, and I reduced the opacity of the drawn shadow to 40%, hoping that will make it less "floaty."
    QuentenLoopysueRyan ThomasRalfRicko
