Royal Scribe
Royal Scribe
- Royal Scribe
- 9,539
- Member
- 3,353
- February 5, 1968
- San Francisco, California
- Website
- Real Name
- Kevin
- Mapmaker
- 16
Reactions
[WIP] Republic of Lumadair (Ancient Realms Revisited)
I agree for the same reason: seeing more of the tower. I changed the varicolor to be a slightly darker yellow.
Here are a few more options. Top left is from DD3 Creatures (tried to make it look like it was crawling up the tower), top right is from CA15 Heraldic Symbols, and the bottom two are from Shessar's heraldic symbols (dragon on left, wyvern on right). I'm leaning towards Shessar's wyvern in the lower right.
Birdseye Continental - style development thread
Thank you, @Wyvern!
If you have it, you could try one of the two original Character Artist ready-made dragon symbols
I do have Character Artist, but I haven't used it much and didn't realize those were there. This vastly expands my heraldic symbol options! Here it is using the traditional dragon with a tower icon background. I also tried one with a wyvern off to the side. Which is your favorite?
You might want to add a marker of some kind - even a simple dot - for the Caverns of Dread
I actually did have a cave hole there, but it was kind of small and I used a fill that ended up being kind of a washed-out gray at this zoom. I deleted it and drew in an oversized black "cave mouth" polygon.
I have previously done the Republic of Lumadair, a portion of my campaign world, in many different styles. (There's an album in my galleries showing the different approaches.) I find it helpful to compare styles with a consistent coastline and terrain.
Anyway, here's a first pass at trying it with the new Ancient Realms Revisited annual.
I ended up using tower symbols instead of cities to show the major unnamed cities. I've only done a few of the icon symbols for major points of interest, though I can do more. Instead of putting the icons exactly where the locations would be, I put them off to the side with a dotted line to the actual location (similar to how I approached my Modern Journeys map).
This sort of forest approach rather than individual symbols isn't my favorite approach, but it's growing on me. For the coastal cities, maybe I should trace the coastline rather than being more freeform? Ralf brought in some Mike Schley symbols (Asian settlements) in his video tutorial, so maybe I will try that with Mike's tree symbols. I'm worried, though, that those tree symbols would make this look too much like a knockoff of Mike's overland style and not its own thing.
I did one custom symbol of a dragon, but I'm not thrilled.
I used a parchment background but maybe a solid color would be better? (The icon background is on a separate sheet, so I could see if a texturize effect helps.) Or I could put a tower icon as the main icon with a dragon over it. If anyone knows of better dragon symbols to use, let me know. (I thought about the heraldry icons from CA15, but I'm not so sure.)
WIP: Bleakmoor Harrow - Continent of Estonisch
