Royal Scribe
Royal Scribe
- Royal Scribe
- 9,539
- Member
- 3,353
- February 5, 1968
- San Francisco, California
- Website
- Real Name
- Kevin
- Mapmaker
- 16
Reactions
[WIP] The Old San Francisco Mint (Dracula Dossier)
Okay, I changed it on the Floors 3 and 4 maps, too. While they aren't suitable for the Atlas in their current forms (though I could always tweak them to be a museum or other building), I would still like to offer them up to any Game Masters who would like to use them in whatever campaigns they're in. (I will also post that message to the FB group to reach a different audience than the forums.) For anyone who would like to use them, here are the FCW files with my blessing.
Went in to change the outside landscaping in the second floor file and noticed that I forgot some of the windows, especially on the main entrance side. @Don Anderson Jr., does this achieve what you recommending with the landscaping for the higher floors: keep the fence but eliminate the foliage? I kept the fence and added a Solid 20 fill (which I could change to Solid 10 if it looks too strong).
I forgot to answer this question:
Did you add buttons to switch the views, or is it all separate maps?
They are all separate maps. I have done some where there are navigation links to open other levels, and others where it's all in one FCW with layers hidden. In this case, they are separate files but I didn't add navigation links because I liked the sleeker look without them.
Yea, thats right, the stairs start at the sidewalk and ascend to the second floor entrance. Here’s a photo I took last weekend:
So you think the outside terrain should be shown on all levels? Should I mask it a little with something like the Solid White transparencies? That’s what I did from the upper views of the courtyard.
I was inspired by Christina's most recent All the Annuals post and decided to use that as motivation to try out the Dracula Dossier annual from 2015.
My initial thought was to design the old San Francisco Public Library Main Branch, which is now the Asian Art Museum. I had a thought about how adventurers might have to go there to find an ancient tome hidden while it was still a library to use to banish an ancient eldritch evil. I couldn't find good floor plans of it,* though, so I poked around to find floorplans of other old SF buildings and settled on The Old San Francisco Mint.
I was able to find lots of floor plans because the first two floors are now used as an event venue -- weddings, corporate events, and an incredible adults-only haunted mansion in October called Terror Vault. Some things may be different -- I have a feeling, for example, that the original mint didn't have quite so many ballrooms. And what was once the first vault is now the base of an elevator shaft.
The Mint was built in 1874, replacing one that had been built in 1854. It survived the Great Earthquake and Fires of 1906, which is good because at the time, it was home to a third of the U.S. Government's gold deposits. It was decommissioned in 1937 after a new mint was built across town (which we still call The "New" Mint even though it's over 85 years old).
The main entrance is on the second floor, but there is a wheelchair entrance, freight entrance, and emergency exit on the first (ground) floor, so I will start with that. I have gridded pix as well that could be used for an RPG, but for now, here are the ungridded ones.
Ground Floor
Emergency exit on the Mission Street side, wheelchair entrance on the opposite side (Mint Plaza), and a loading entrance in the rear (Mint Street). It's primarily accessed from the second floor, though, through a freight elevator in what was Vault 1, or through one of four sets of internal stairs.
Second Floor
The main entrance from Fifth Street leads up exterior steps to this level. This level also has a courtyard covered by a glass roof.
Third Floor
I eliminated the foliage outside except for the trees, which I thought might reach close to the third floor windows. The columns here do appear on the floorplans I found.
Fourth Floor
Note that the columns are now covered by the fourth floor, which serves as a roof for them. Looks like there's some office space on the Fifth Street side, and some utilitarian space on the opposite side, but mostly it's just roofing over the third floor.
* I subsequently have found good floorplans for the Old Library! When I went downtown to take photos of the Old Mint, I decided to swing by the new Main Library's History Center, and they did have the floorplans. They will be coming in a future project, maybe with a different floorplan annual.
