Royal Scribe
Royal Scribe
- Royal Scribe
- 9,537
- Member
- 3,353
- February 5, 1968
- San Francisco, California
- Website
- Real Name
- Kevin
- Mapmaker
- 16
Reactions
Tell me all about your DnD campaigns!
I have played D&D off and on since around 1980, but the last longer campaign I was in ended around 2009 or so. Some time around 2016, I decided to start building my campaign world in preparation for getting a new group together. I spent some time researching mapping software before settling on Campaign Cartographer. In the years between buying the software and finally learning how to use it, I was writing up a lot of the lore for my campaign world, first in MS Word before finding a few Wiki plugin for my WordPress website. Lots done in the Religion section, along with some in History and Geoscience.
Still haven't actually DM'd in this world yet. Another group of friends who I had never played with invited me to join a campaign they were launching. We had a few sessions before COVID hit, and then tried one remote session on Discord that was a complete disaster, and everything fell apart. So I got back into my own worldbuilding (which can be a fun activity in its own right), and then started getting into map-making. I admit that Campaign Cartographer has taken over my hobby time and I've neglected the world-building.
Meanwhile, the old group that I played with in the early 2000s is getting back together. One friend who was part of that group, and whom I've played with off and on since 1989, moved back from New York and decided to DM a Pathfinder campaign for us. So my world is still off on its own as I dive into his world...but my Wiki still exists. And so I present to you: the World of Adnati.
[WIP] Villa Citri (Roman-style villa)
Here's the third floor.
The outer walls here are accessed through the spiral staircases in the gatehouse towers and the corner towers. From there, arched doorways secured with metal doors provide access to the parapets of the outer walls. Stairs on these parapets lead to the top of the towers.
The main villa has two disconnected suites on this floor, nicknamed the Green Apartments and the Blue Apartments because of the color of the tiles. Each is accessed by separate spiral staircases from the second floor. Each has an outer reception room, a private dining/lounge area, an office, and a relatively spacious bedrooms. In previous generations, the Lord and Lady of the manor had separate suites. It is currently occupied by the Dowager Countess of (I forget), who resides in the Caeruleum Residentiae (the blue suite), as it is heated by the hypocaust's flue and the other apartment is not. The other suite is the guest quarters for her son, the current Earl of (I forget) when he visits.
The upper floor is the bathhouse is currently used for storage.
Okay, here's the second floor again with the courtyards with the same parchment mask as the rest of the outside. There's actually just one mask over the entire thing, but I punched a hole in it with the color key cutout effect. I guess I was thinking "inside v. outside" instead of "this floor v. lower floors." The magenta polygon is now on a COURTYARD layer, so it can be turned on or off depending on which approach is preferred.
I'm still toying with the idea of making the legend's text look like it's engraved, but I'm not sure if it shows up well enough?
I tried it out with Marine Dungeon's brass inlay that I love so much. Here it is with both the red marble on the right side and the black marble on the left (with the original colored text as a comparison). It looks good on the dark marble but only if you're zoomed in.
And then I tried it again with a goldleaf fill. As much as I love the brass (plus it's native to Marine Dungeons, so it's not added another annual to the mix), the goldleaf may be a little easier to read because it doesn't have the reflected light effect. This one also only really works with the darkest marble.
Brass Inlay
Goldleaf
Thoughts?
Okay, the second floor is mapped and furnished!
Outside
- Muri Magni: Inside the second floor of the outer wall in a 10-foot-wide passageway with arrow slits at regular intervals.
- Portae Turres: The gatehouse towers
- Turres Anguli: The corner towers
- Scalae: Exterior staircases open on one side that lead to the second-floor entrances of the corner towers
Villa
5. Portico Roof: The roof of the covered porch
6. Scalae Graecae: Staircase from the first floor
7. Scala Spiralis: Spiral stairs leading to the third floor
8. Cenaculum: The dining room on an upper floor of Roman houses
9. Heating Caliduct: Hot air from the hypocaust in the basement of the balneae flows through this shaft to heat the floors
10. Puteus & Puteal: An interior well with unheated water
11. Lavatrina: Lavatories
12. Cubiculum: Bedroom
Balneae
13. Colonnade Roof: The roof of the colonnade that connects the main villa to the bathhouse
14. Scalae Graecae: Staircase from the first floor and up to the third floor
15. Hypocaust Chimney: Exhaust vent for the vast amounts of smoke generated by the hypocaust in the basement
16. Armorium: Closets
17. Bibliotheca: The library, including a reading area overlooking the tepidarium pool
18. Palaestra: An exercise area and prominade
19. Gymnasium: Exercise equipment
