Royal Scribe
Royal Scribe
Royal Scribe
9,537
Member
3,353
Birthday
February 5, 1968
San Francisco, California
Website
Real Name
Kevin
Mapmaker
16
  • Atlas Submission: Doriant - Gold Coast - Tyr Alomere
    I realized in the middle of the night that I forgot something -- the cutout in the parchment that allowed the courtyards to be shown without the parchment filter. There should be another toggle for the Floor 2 and Floor 3 files, second and third floors: the COURTYARD layer. Hiding it hides the magenta polygon, causing the courtyards to be hidden behind the gauzy parchment.
    Or if you think that will just be too confusing, here are some FCW files that delete the magenta polygons, so the courtyards are always included when the outside areas are grayed out.
    Thank you, Sue! I’m delighted that Marine Dungeons can be so versatile for even things that aren’t mostly underwater. I’ve been wanting a Roman style annual and it was there all along. 😉
    Don Anderson Jr.Loopysue
    Third floor.
    Toggles
    PARCHMENT layer to hide/reveal the layer of parchment that provides a sort of sepia filter over the outdoor areas.
    TEXT LABELS (NUMBERS) layer to hide/display the numbered labels.
    TEXT LABELS layer to hide/display the legends describing the labeled numbers.
    Files
    The third story of the Villa Citri and its estate.
    Outside
    1. Muri Magni Parapet
    The open-to-the-sky crenellated rooftop walkway of the Great Walls can be accessed through arched doorways from the corner and gatehouse towers. Metal doors protect the towers from intruders. Stairs ascend to the rooftops of the corner and gatehouse towers.
    2. Portae Turres
    The upper stories of the gatehouse towers have spiral staircases descending to the second floor, and arched doorways providing access to the parapet. It also provides access to the Porta Rampart, a parapet over the gates.
    3. Porta Rampart
    A parapet over the gates from which guards can address visitors to the villa.
    4. Turrim Cubiculi
    The chamber at the top of the corner towers. Each has a staircase that descends to the second floor and arched doorways that provide access to the Great Wall’s parapets.
    5. Gradus Superiores
    Staircases that ascend from the crenellated parapets to the rooftops of corner and gatehouse towers.
    Balneae
    6. Scalae Graecae
    Walled staircase that descends to the second floor.
    7. Horreum Cenaculum
    An attic used primarily for storage.
    8. Camini
    The chimney venting smoke from the hypocaust’s furnace.
    Villa
    9. Viridi Residentiae
    The “Green Apartments,” so named for the color of the tiled floor, is one of the two luxury suites. In prior generations, the Lord and Lady of the villa sometimes maintained separate residences. This suite is currently used by the Earl of Westford when he visits his mother.
    10. Viridis Vestibulum
    An outer reception area for the Green Apartments.
    11. Viridis Zotheca
    A private lounge and dining area for the Green Apartments.
    12. Viridis Bibliotheca
    An office and small library.
    13. Magnus Cubiculum
    The main bedroom for the Green Apartments.
    14. Caeruleum Residentiae
    The “Blue Apartments” are named for the blue tiles on the floor. Unlike the Viridi Residentiae, the floors here are heated. The Dowager Countess of Westford occupies this suite as her own residence.
    15. Caliduct
    Hot air from the hypocausts vents from here to heat the floors of the apartment,
    16. Caeruleum Vestibulum
    An outer reception room for the Blue Apartments.
    17. Caeruleum Zotheca
    A private lounge and dining area for the Blue Apartments.
    18. Caeruleum Bibliotheca
    19. Magnus Cubiculum
    The main bedroom for the Blue Apartments.
    Toggles
    Here's the second floor.
    Toggles
    Files
    The second story of the Villa Citri and its estate.
    Outside
    1. Muri Magni
    On this level, the great outer walls of the estate have a ten-foot-wide central corridor that allows for defenders to be protected while shooting arrows through arrow slits.
    2. Portae Turres
    The second story of the gatehouse towers includes a spiral staircase that extended from the first floor all the way through to the third floor. Arrow slits allow for defending the main entrance to the villa’s estate.
    3. Turres Anguli
    The corner towers can be accessed from the ground floor via external staircases. Each has a spiral staircase leading to the third floor.
    4. Scalae
    These external staircases, unwalled on one side, provide access from the outside grounds to the second stories of the corner towers.
    Villa
    5. Portico Roof
    Windows from the second story provide a view of the roof of the covered portico, or front porch.
    6. Scalae Graecae
    Staircase enclosed by walls on both sides.
    7. Scala Spiralis
    Spiral staircases that provide access to the third story.
    8. Cenaculum
    The private upstairs dining room on an upper floor of Roman houses.
    9. Heating Caliduct
    Hot air from the hypocaust is piped through here to heat the second story floors.
    10. Puteus & Puteal
    A chamber (puteal) that houses a wellhead inside the villa. Water is piped in to the well from the river.
    11. Lavatrina
    On this floor, the lavatories do not have a direct connection to the sewers. Instead, each has a cabinet over a chamber pot that is periodically emptied and clean by the villa’s servants.
    12. Cubiculum
    The guest bedrooms on this floor are a bit nicer than the ones below.
    Balneae
    13. Colonnade Roof
    As the colonnade is only one story high, the views here provide a glimpse of its roof.
    14. Scalae Graecae
    Walled stairs connects this floor to both the first and third floors of the bathhouse.
    15. Hypocaust Chimney
    Brings the smoke from the hypocaust’s furnace to be vented to the outside.
    16. Armorium
    A closet.
    17. Bibliotheca
    The villa’s main library has a vast collection of books and scrolls, as well as several seating areas, including a lounge overlooking the tepidarium.
    18. Palaestra
    This exercise area includes a promenade overlooking the tepidarium.
    19. Gymnasium
    This room includes exercise equipment for use here or in the palaestra.
    Here's the first floor:
    Toggles
    Files
    The ground level of the Villa Citri and its estate.
    Outside
    1. Muri Magni
    At the ground level, the great walls that surround the estate are solid stonework, as are this section of the corner towers.
    2. Portae Turres Controls
    Each of the gatehouse towers has a chamber access by a short flight of stairs that house the controls for the gate and the portcullises. Both sets of controls can operate the gates independently of the other. Solid metal doors guard the entrance to these chambers, and metal gates at the top of the stairs also provide further protection. A spiral staircase in each ascends to an upper story of the gatehouse.
    Villa
    3. Portico
    This covered porch of red marble has four column pillars supporting the roof, as well as a railing of black marble.
    4. Vestibulum
    The entryway leads to the atrium, where guests may be greeted by their host.
    5. Atrium
    Guests are received by their host in this central area. Though the walkways are covered by the floors of the second story, sunlight from an opening in the roof (called the Compluvium) over the central pool keeps the room well-lit during the day.
    6. Impluvium
    The pool in the center of the atrium, called the impluvium, is positioned beneath an opening in the ceiling, called the compluvium. Rainwater collects in the pool and is then piped to a cistern used in the kitchen.
    7. Triclinium
    The villa’s main dining room has couches arranged in a U-shape, with a short table for food in the center of them.
    8. Tablinum
    The open office is used by the proprietors of the villa to conduct business with guests while keeping an eye on both courtyards. An enclosed chamber (8A) allows for more private work.
    9. Culina
    The villa’s kitchen includes a well with water piped in from the impluvium, though this villa supplements it with additional water piped in from the river. The wood-burning stove vents directly to the outside.
    10. Cellarium
    The pantry for the kitchen can only be accessed from the kitchen.
    11. Lavatrina
    The lavatories on this level all have shafts where waste is deposited directly into the sewers.
    12. Horreum
    These rooms are used for storage.
    13. Cubiculum
    On this level, there are six cubiculae, or bedrooms, surrounding the peristylium courtyard. On this level, the bedrooms are mostly used by guests.
    14. Scalae Graecae
    A staircase enclosed by walls provides access to the second story. An archway also provides access to stairs that lead to the basement.
    15. Andron & Gynaeceum
    In ancient times, the Andron (#15a) was used exclusively by the men of the household for libations and conversation, while the Gynaeceum was used by the household’s women. Both are now used as front parlors for socializing.
    16. Alae
    These two chambers flanking the courtyard are used to honor the family’s ancestors.
    17. Peristylium
    This courtyard, which is also open to the sky, has a central fountain, with column pillars surrounding the courtyard.
    18. Piscina
    The central fountain beneath an opening in the roof collects rainwater, but water from the river is also piped in to keep the fountain operational in dry months.
    19. Exhedra
    This semicircular seating area is used for socializing. A brazier enchanted with a Continual Flame spell allows for heatless, smokeless flames to provide lighting in the evenings. A second enchantment allows for heat to radiate from it when desired on colder evenings.
    20. Lararium
    The chambers flaking the exhedra are shrines for the household’s favored gods. The braziers here, like that in the exhedra, are enchanted with a Continual Flame spell.
    21. Posticum
    The rear exit is used by the villa’s servants, as well as by the villa’s residents and guests when they wish to avoid the front entrance.
    22. Heating Caliduct
    This pipe brings hot air from the hypocaust in the basement to warm the villa’s upper stories.
    23. Puteus & Puteal
    24. Colonnade
    A covered walkway surrounded by columns instead of walls connect the villa to the balneae, the bathhouse.
    Balneae
    25. Scalae Graecae
    Walled stairs ascend to the bathhouse’s second floor and descend to the basement.
    26. Lavatrina
    Lavatories with shafts that descend directly to the sewers.
    27. Hypocaust Chimney
    Connects to the hypocaust in the basement which is used to heat both the bathhouse and the villa, and to provide for hot water.
    28. Apodyterium
    A changing room for those using the balneae’s amenities, as well as to wash up before using the communal pools.
    29. Frigidarium
    A cold-water pool that provides for an invigorating plunge before being warmed up in the bathhouse’s warmer pools. The hypocaust does not extend below this room, so it is kept chilled even as the rest of the bathhouse is kept warm.
    30. Caldarium
    A hot-water pool located directly above the hypocaust’s furnaces keep the water as warm as any bath.
    31. Tepidarium
    The water in this pool is piped in from both hot- and cold-water cisterns, keeping the water at a comfortable and refreshing temperature. Though this area is open to the sky, at least over part of the pool, the tiled floor is heated by the hypocaust.
    32. Sudatorium
    A steam sauna, with hot water from the hypocaust poured over heated rocks to provide for steam.
    33. Laconicum
    A dry sauna heated from the hypocaust in the basement below.
