Royal Scribe
Royal Scribe
Royal Scribe
9,533
Member
3,353
Birthday
February 5, 1968
San Francisco, California
Website
Real Name
Kevin
Mapmaker
16
  • Ideas and Wishes for Monthly Dungeon Symbols
    Reviving this old thread to throw out one more idea, though I wouldn't be surprised if Mike is all booked up until it's time to shift to cities or something.
    I love all of the stuff that Mike has added this year -- and I've managed to add a little something from each month's to my new Schley-style wizard's tower. But in furnishing the tower, there was one area I noticed could use a bit more: food and beverage. There are plates of food, but DD3, in comparison, also has individual food items, as well as solo plates, bowls, silverware, etc. I would love to see something like a Tavern update that includes food items as well as, in particular:
    • Drinking vessels (goblets, mugs, tankards, etc.)
    • Bottles upright and on their side (which I've used in DD3 to create racks of wine in wine cellars)
    • Bar counter that curves on one side
    • Individual food items (roasted meats, baked goods, eggs, fruit, etc.)
    • Individual plates, bowls, silverware
    Fully understand if Mike's plate is full (pun intended) but figured I'd throw that out there.
    QuentenRickoboffo
  • [WIP] The Wizard of Schley
    Still haven't finished the basement (got sidetracked with Cosmographer), but revisiting this to add some of the newest monthly symbols. I experimented with adding tombstones #4 and #5 from Mike Schley's latest monthly as decorations on the top of the tower, like where gargoyles and grotesques would go, but I couldn't get them to look right. And creating a little graveyard outside of the tower looked weird on such a small hill. But I couldn't resist doing something with the new symbols, so I added tombstone #4 as a statue amidst the trees on the western side, and the wheelbarrow next to the vegetable garden.
    I think I've managed to get something from each of the 2025 monthly dungeon-scale symbols into one or more of these Wizard of Schley maps.
    Don Anderson Jr.MonsenRickoroflo1QuentenRalfGlitchseycyrus
  • [WIP] Research Saucer Shuttle
    Here is the saucer shuttle from below.
    I named this shuttle The Osprey. It is of a class of saucer ships that I've named a Nimbus Class. These shuttles are assigned to either a space station or larger interstellar vessel. In this case, it is part of The Perception, a research ship from a class of ships that I am calling the Copernicus Class.
    On the left side, the airlock hatch can be opened planetside to extend a ramp. The very center has a docking ring for connecting to The Perception or other vessels or space stations. The twelve glowing disks are meant to be some sort of magnetic propulsion thrusters (the side thrusters are more for steering and course correction, not liftoff or acceleration). They were made using one of the sun symbols that come with Cosmographer. And the six metal disks are meant to be places where retractable legs can extend when on planet.
    The text labels on the right are for toggles in the FCW file. They are off the map border and normally don't print, but I wanted to show it to you. They are mostly on/off toggles, but the Tractor Beam is a little more complex, which I will get to. Here is the syntax for the thrusters, as demonstrated in Remy @Monsen's recent Village Battlemap tutorial. It toggles between hiding and unhiding the layer called "Symbols - Thrusters".
    GOLAYER BACKGROUND
    TOGL Symbols - Thrusters
    NULL
    As Remy's tutorial explains, the GOLAYER line is done to make sure you aren't on the layer you're trying to hide, because active layers cannot be hidden. And the NULL line is to make sure that toggling a layer is not your most recent command.
    Here's the map with the center docking ring open:
    The docking ring is actually two separate symbols, with the closed hatch symbol on top of the open hatch. The "Docking Ring" toggle hides or unhides the sheet that the closed hatch symbol is on, allowing the hatch to go back and forth between open and closed.
    In addition to using the center hatch for docking with other vessels, a tractor beam can be activated to lift cargo or specimens into the shuttle (like cows or battered pickup trucks in the deserts of Nevada). Here is the tractor beam activated (it's one of the varicolor suns):
    The toggling of the tractor beam was a little tricky. I suppose I could have made it just be on top of the hatch symbols, but I decided to make it as separate "on" and "off" options. Clicking "on" simultaneous hides the layer that both docking hatch symbols are on while unhiding the layer that the tractor beam is on. Here's the syntax for turning it on:
    GOLAYER BACKGROUND
    HIDE Docking Hatch
    SHOW Tractor Beam
    NULL
    Clicking the "Off" link reverses this, hiding the tractor beam layer and showing the docking hatch layer.
    On to the Habitat and Engineering decks!
    LoopysueQuentenRyan Thomas
    I've never really used Cosmographer much, other than borrowing starfield bitmaps or planets as backgrounds for other maps. Here is the beginnings of my first spacecraft.
    It's a small saucer shuttle, 50 map units in diameter. (I think the map units are in feet but not entirely sure.) My thought is that it's capable of flying through a solar system but not capable of interstellar flight. Usually attached to a space station or larger interstellar vessel, used for getting a closer look to study planets, entering the upper atmosphere or even landing planet side, collecting flora and fauna for closer study.
    So far, I've just done the outside from above and the top-most deck -- the Command and Scientific Research deck. There will be two more decks: the Habitat deck in the center, and Engineering & Cargo on the bottom. I will also do a view from below.
    From Above
    Here it is from above, with windows shuttered and dome closed, defensive shields activated.
    Windows unshuttered, dome uncovered:
    I did a lot of experimenting on the windows, including experimenting with using Blend Mode. That worked out, but I ended up settling on using a Color Key cutout (of course) -- but instead of using the traditional magenta color (#6), I used the light blue (#5) and set it with a 20% opacity. I figure it's slightly tinted.
    Here it is with retractable thrusters out:
    Those gray discs are meant to be retractable hatches for weaponry and sensors. Here it is again with the four weapons (two lasers, two torpedo weapons) and four sensors out:
    Top Deck: Command and Scientific Research
    I was going to divide this floor into separate rooms, but it looked funny with the "skylight" windows. I suppose it makes sense for a research shuttle to allows the scientists and command crew to be together, since the scientists will really be directing the mission.
    I played around with different stair options but didn't really care for them. I ended up settling for an elevator lift on the southern side, with an emergency ladder shaft on the northern side. Command/flight stations on the eastern side, scientific study stations elsewhere. Labels to come.
    That's it for now. The other two floors and the bottom view still to come.
    Ryan ThomasLoopysueMonsenroflo1Quenten
  • Unnamed city in progress
    This is great. I have a couple of large cities that I’m planning to do, and have been pondering approaches. Using separate layers for each neighborhood sounds like a good idea, and I will study CA129. I think I may do one in SS5 and the other in Darklands City. Any tips — anything you wish you had done along the way or before getting started?
    Don Anderson Jr.
