Royal Scribe
Royal Scribe
- Royal Scribe
- 9,533
- Member
- 3,353
- February 5, 1968
- San Francisco, California
- Website
- Real Name
- Kevin
- Mapmaker
- 16
Reactions
[WIP] Playing around with Sinister Sewers
I made a few tweaks. Changed most of the effluent to brown except for the portions from the vents (aka storm drains) that's meant to be rainwater. Added a few bunches of leaves from Forest Trail to those ones. Added some bridges for maintenance workers to use to cross canals. Left a bit of green coming from one of the canals -- a mystery for adventurers to solve? I should probably add some slime....
Getting a little practice in with Sinister Sewers this afternoon. (I've been mentally mapping out an elaborate waste management system, but this is just for practice.) If I'm lucky, Ralf will do a demo with the next Live -- looking forward to seeing his strategies and tips.
The canal in the lower left is meant to be regular water from a storm drain (maybe I should add some leaves) that would normally mingle with the effluent and push it through, but a gelatinous cube is gobbling up all the leaves and everything. (My waste management system will make extensive use of oozes to keep things tidy.) I used Effluent 05 for the water. Was that intended to be regular water? Is there a better approach for that?
I ended up going with the green effluent for most of it because I liked how the colors popped. But I will probably use the browns and yellows mostly, maybe with the green used for scum, and maybe waste "water?" coming from the sewers connected to a necromancer's lab.
I was struggling getting a break in the wall to the room without canals to work properly, and then realized that an archway was a perfect gimmick. This room was intended to be the main access to the sewers, but there are also ladders or rungs near the surface vents. Threw in some carnivorous vegetation for fun. Maybe some adventurers will be hired to find out why waste management workers are disappearing.
Castle in a Cloud
Thrilled to be included in the January 2024 Maps of the Month post, but I just noticed that although I posted the corrected map in the Facebook group, the final map here still has some upside down trees! Posting the corrected one now since the blog post links here.
OSR Dungeon Tiles - Quick Test
New Mike Schley Glaciars Content
