Royal Scribe
Royal Scribe
Royal Scribe
9,537
Member
3,353
Birthday
February 5, 1968
San Francisco, California
Website
Real Name
Kevin
Mapmaker
16
  • A small carpenter store
    It's really great. I particularly like how you did the fence posts and railing. I can't think of anything I'd change or add.
    Cristian MustiataRicko
  • Kadria
    Wow! That’s a very dramatic map. Beautiful!
    Ricko
  • [WIP] Haunted Mansion
    Working on the inside of the church first before tackling the mansion, though I've been taking notes on the types of rooms one might expect in a medieval mansion. (Suggestions welcome.) I've just done the first floor so far.
    Here's the outside.
    The end portions of the right and left wings are actually covered porches, so the floorplan for Floor 1 will show the porches, and Floor 2 will show the roofs covering the porches.
    Here's the inside. I used the parchment approach that Sue used with the Beaumaris Castle annual to cause the outside to fade out a bit. The four stairwells all go up and down.
    Downstairs, the basement is mostly below ground, but a small portion is above ground, just enough for some high windows to let in daylight. The priests' offices are down there along other rooms. There might be some common rooms for church events (what's the medieval equivalent of Bingo?), but most of that sort of thing probably occurs at the Church Hall on the west side of the plaza. This level will include a room used to prepare bodies for funeral services. Another basement below that will contain catacomb crypts for VIP decedents buried beneath the church rather than in the graveyard beside it. The crypts will have a secret access to the sewers, which also connects to the sewers from the haunted mansion, allowing for secret travel between the church and the mansion (a plot point I'll share when all of the mapping is done.) The second floor will contain balconies. One will in the back between the belltowers, with more pews. The two sets of stairs on the north side of the church will lead to balconies on the east and west sides used primarily by the choir, although they can also accommodate more private seating for visiting nobles.
    Here's a blow up of the altar area. The north side is raised a few steps up.
    QuentenGlitchLoopysueJuanpiCalibre
    No, they’re actually Fog symbols from Creepy Crypts! I had to make them 4 times larger because they’re sized for a dungeon, not a city.
    Ricko
    Slight tweak. I started to work on the interiors, but as I was working on the church, I decided that I really needed to add a few belltowers because it was the only place I could work out getting stairs up to the balcony at the rear (entrance side) of the church. Added some labels while I was at it, but only on the daytime map. Maybe I will be able to get some interiors posted before the end of the weekend.
    RickoLoopysueMonsenGlitch
