Royal Scribe
Royal Scribe
Royal Scribe
9,536
Member
3,353
Birthday
February 5, 1968
San Francisco, California
Website
Real Name
Kevin
Mapmaker
16
  • [WIP] Haunted Mansion
    Made some tweaks to the second floor. I forgot that I planned to have a smaller family dining area on this floor. Ended up converting the office to a small dining room, as it has a nice fireplace and seemed cozier than the solarium. The head of household can do their books and office work in the library. Rearranged the appurtenant WC so that it's accessed from the hallway rather than the dining room. Still haven't figured out the white line with the paths (under the steps leading to the servants' area on the first floor).
    LoopysueRickoCalibreQuenten
    Probably won't have a chance to finish this by the end of Halloween, as I had planned, but that's okay. Here's the second floor. It has a few guest bedrooms and some common space for the family: an office, a library, and a solarium or sun room. The ballroom extends into this level, as it has high ceilings, but it is from this level that the family and VIP guests can make grand entrances into the ballroom from the stairway.
    Not really sure why my roads outside now have a visible white line down the center. I tried changing the color to brown, but that didn't work.
    Just noticed that in addition to failing to furnish the office, I also neglected to put in a doorway!
    Still to come: floor 3 (bedrooms), the top floor of the tower, Basement 1 (kitchens, wine cellar, staff quarters, etc.), a secret Basement 2, and the sewers that connect everything together.
    LoopysueRickoMonsenQuentenGlitch
  • Invasion of the Pod People
    Coincidentally, I happened to watch one of the remakes of Invasion of the Body Snatchers (the 2007 Nicole Kidman film Invasion) the night before Mike Schley's latest monthly symbols were released. Just for fun, I decided to do a quick-and-dirty map with the new Hive Civilization symbols. I hadn't gotten a chance to play with the Mesoamerican symbols (busy making villages when those symbols came out!), it gave me an excuse to try them out, too.
    If there's a Hive expansion next month (they tend to come in pairs), maybe I will revise this same map to show the Kheek'zit invaders' expansion onto the mainland.
    LoopysueRickoQuentenGlitchShessarCalibreJuanpi
    Reversed my plan for the Mansion -- originally, the main entrance was going to be on the southern side, but things seemed to fit better with the main entrance on the other side. For the servant's areas are mostly a level below, with a small area here where they can serve the dining room. I couldn't find wooden stairs suitable for this style that went both up and down, or that could be stacked (Mike Schley's style didn't fit and the other wooden ones couldn't be stacked because they had landings drawn in), so I went with stone stairs for the servants. Used some of Shessar's lovely fireplaces, and some ghosts waltzing in the ballroom from Dundjinni Archives. (They might be a little big -- the ballroom is 30 feet wide.) Shadows didn't make sense for the ghosts, but I wasn't sure if it conveyed that they were floating, so I added some glows from DD3. Still need to add more furnishings, and then on to the upper and lower floors.
    LoopysueMonsenRickoShessar
    I'll be starting on the actual Haunted Mansion part of this Haunted Mansion Map today. But first, here's the rest (almost) of what's going on in the church and graveyard.
    Here's the first level of the church's basement.
    It may seem odd that a basement has so many windows. This basement is only about 75% below ground. The top 25% is above ground, and that's where windows to let light in are located -- close to the ceiling from the inside, but at foot level from the outside. There's a set of double doors connecting to a interior ramp that leads out to the graveyard. The mortician has two rooms here, one for preparing the deceased for funerals, and another that connects to a lower storage room in Basement 2. This level also has a few offices for the priests and clergy staff, a few storage rooms, and lavatories. Other than the doors from the graveyard, it is primarily accessed from the four stone spiral staircases (the two southern ones going all the way up to the bell towers, and the two northern ones going to balconies for the choir in the main chapel.
    Continuing down into Basement 2, we find the mortician's storage rooms (including a stack of unused coffins) and the church's crypts for VIP decedents. I kept the shafts for the wells here so that I wouldn't accidentally create passageways through them. The two shafts that aren't connected to the crypts come from the lavatories in Basement 1 as well as the drain in the mortician's room. They connect to the not-yet-mapped sewers one more level below. (Sinister Sewers will come in handy again!)
    But wait! Not all is as it seems here. There are two secret passageways off of the mortician's storage rooms. (I love that the cut-away polygons used to carve out tunnels can be moved to the "Secret" layer so that they can be hidden or revealed so easily.) The passageway heading west connects to a secret spiral stairway entrance to the Rectory. Who knows how many generations ago it was put in -- the church's current head priest, who lives in the rectory, doesn't even know it's there! The second passageway heading north connects below the Brambleheath Tombs, created by the Brambleheath family who also built the now-haunted mansion.
    But wait again! One more secret here. If you remove the lids to the sarcophagi and coffins, you'll notice that a few have moldering remains but most are actually empty. They all have proper plaques naming the supposed occupants. It's unclear if the bodies were remove after burial, or if they never made it into their coffins. One on the northern side is filled with rocks, suggesting for that one, at least, it was interred without a body.
    The sewers will come later, after I've done the Mansion. For now, let's head over to the Brambleheath Tomb. When you enter the tomb, a Glyph of Warding protects it from graverobbers. For a family tomb, it's surprisingly small: one large sarcophagus on the floor, two smaller ones on ledges to either side of it, and two urns with the cremains of other ancestors.
    Visitors who make it past the Glyph of Warding can trace their finger along a sigil on the sarcophagus lid that activates a temporary levitation spell, raising the lid to reveal a staircase heading down. (I love this symbol set!)
    The lower level of the tomb reveals a "small"" family crypt.
    But wait, more secrets! A passageway heading south on the eastern side (this is the passage that connects to the mortician's storage room beneath the church, and another passageway that heads down stairs and then turns to head beneath the graveyard towards the mansion. If we open the coffins and sarcophagi here, we see that most do have bodies. It's hard to tell because they're in shadows, but the northeastern-most one was buried with a sword, and the one next to it was buried with a staff. Plot hooks!
    That's it for now. Haunted Mansion and sewers still to come...
    LoopysueMonsenQuentenGlitchJuanpi
