Royal Scribe
Royal Scribe
- Royal Scribe
- 9,537
- Member
- 3,353
- February 5, 1968
- San Francisco, California
- Website
- Real Name
- Kevin
- Mapmaker
- 16
Reactions
[WIP] Haunted Mansion
Here is Basement 2. Most of it is taken up by the mansion's sewer system, including a branch that comes from beneath the barn. There are shadows from the shafts above where waste is deposited into the sewers. Waste flows to the southern-most part of the line, where a chute connects the mansion's sewers to the municipal sewers. There are also two shafts here to connect the wells (one in the barn) to the water table below.
The secret stairs from the wine cellar connect to a small area here, with more stairs continuing even further below.
Here's a zoomed-in look at the chute that also shows a closer look at the effluent (with sheet effects copied in from Sinister Sewers).
Here's level 4 of the mansion. There were only supposed to be three floors of the main mansion plus the tower, but when I was halfway through the third floor, I noticed that the main mansion has a central section that rises above the others. I decided to make that more of a rough attic storage space with a few rough servants' rooms. The tower doesn't connect here, but you can see it has been turned into a wizard's workshop. It extends up one more flight.
And I just noticed that I never posted the third floor.
Third Floor
Fourth Floor
Hi Cal,
I would be honored for you to use it. Eventually it will make its way into the Atlas when I find a home for it, but that could be a while. It's still a work in progress, but you're free to use these FCW files as well as the rest that I will post when they're ready.
