Royal Scribe
Royal Scribe
Royal Scribe
9,535
Member
3,353
Birthday
February 5, 1968
San Francisco, California
Website
Real Name
Kevin
Mapmaker
16
  • [WIP] Wizard's Tower
    I have been working on a "small" wizard's tower that uses CA186/188 Creepy Crypts as the base (to facilitate doing the below-ground portions later) with heavy use of the fills and symbols from CA149 Beaumaris Castle.
    I put "small" in quotes because it was intended to be the small one, but has been the victim of scope creep. I was working on a much larger wizard's tower that was the center of a much larger fortification, but put it on pause to do this one as a proof of concept. My "small" tower ended up being 80 feet in diameter with at least six stories in the main structure and at least two more stories rising above that. (There are also plans for at least three basement levels, including the sewers.)
    I wanted to do a tower where the stairs wind around the outside, like the Sage Tower from Mike Schley's Overland symbols:
    Given the diameter I picked, the steps ended up going about three-quarters around. It has 146 steps. Since each step has a rise of 7.5 inches, the steps reach a height off the ground of 1,095 inches, or 91.25 feet. And as you can see, the exterior steps don't go all the way to the top of the tower.
    Here is the exterior view and the grounds, which includes a house for servants and/or guests, a barn, an outhouse, an exotic garden, and a fruit orchard. The tower is on a rocky outcrop on a bluff overlooking a river.
    Per the discussion in this Tree Shadows thread, I drew in tree shadows for each tree so that a battlemap could be made hiding the trees but still showing the shadows of where they are, so that players could battle beneath the canopy. Here it is with the trees hidden but their trunks and shadows still shown:
    (Just noticed that the house disappeared. Must have been on the "Vegetation - Trees" layer. Fixed!
    Onwards to the interior!
    RickoLoopysueQuentenMonsenJuanpiLoreleiCalibre
  • [WIP] The Old San Francisco Mint (Dracula Dossier)
    Ahhh, ok. Not sure when I will get to creating the library layout, but if you're interested, I can email you the photographs of the blueprints from a book the librarian allowed me to photograph. They are in the public domain now in part because of their age but mainly because they're government documents (in the U.S., all government documents are public domain, though classified docs can still be restricted).
    Don Anderson Jr.
    Okay, I changed it on the Floors 3 and 4 maps, too. While they aren't suitable for the Atlas in their current forms (though I could always tweak them to be a museum or other building), I would still like to offer them up to any Game Masters who would like to use them in whatever campaigns they're in. (I will also post that message to the FB group to reach a different audience than the forums.) For anyone who would like to use them, here are the FCW files with my blessing.
    Don Anderson Jr.Loopysue
    Went in to change the outside landscaping in the second floor file and noticed that I forgot some of the windows, especially on the main entrance side. @Don Anderson Jr., does this achieve what you recommending with the landscaping for the higher floors: keep the fence but eliminate the foliage? I kept the fence and added a Solid 20 fill (which I could change to Solid 10 if it looks too strong).
    LoopysueMonsenQuentenJuanpiC.C. Charron
    I was inspired by Christina's most recent All the Annuals post and decided to use that as motivation to try out the Dracula Dossier annual from 2015.
    My initial thought was to design the old San Francisco Public Library Main Branch, which is now the Asian Art Museum. I had a thought about how adventurers might have to go there to find an ancient tome hidden while it was still a library to use to banish an ancient eldritch evil. I couldn't find good floor plans of it,* though, so I poked around to find floorplans of other old SF buildings and settled on The Old San Francisco Mint.
    I was able to find lots of floor plans because the first two floors are now used as an event venue -- weddings, corporate events, and an incredible adults-only haunted mansion in October called Terror Vault. Some things may be different -- I have a feeling, for example, that the original mint didn't have quite so many ballrooms. And what was once the first vault is now the base of an elevator shaft.
    The Mint was built in 1874, replacing one that had been built in 1854. It survived the Great Earthquake and Fires of 1906, which is good because at the time, it was home to a third of the U.S. Government's gold deposits. It was decommissioned in 1937 after a new mint was built across town (which we still call The "New" Mint even though it's over 85 years old).
    The main entrance is on the second floor, but there is a wheelchair entrance, freight entrance, and emergency exit on the first (ground) floor, so I will start with that. I have gridded pix as well that could be used for an RPG, but for now, here are the ungridded ones.
    Ground Floor
    Emergency exit on the Mission Street side, wheelchair entrance on the opposite side (Mint Plaza), and a loading entrance in the rear (Mint Street). It's primarily accessed from the second floor, though, through a freight elevator in what was Vault 1, or through one of four sets of internal stairs.
    Second Floor
    The main entrance from Fifth Street leads up exterior steps to this level. This level also has a courtyard covered by a glass roof.
    Third Floor
    I eliminated the foliage outside except for the trees, which I thought might reach close to the third floor windows. The columns here do appear on the floorplans I found.
    Fourth Floor
    Note that the columns are now covered by the fourth floor, which serves as a roof for them. Looks like there's some office space on the Fifth Street side, and some utilitarian space on the opposite side, but mostly it's just roofing over the third floor.
    * I subsequently have found good floorplans for the Old Library! When I went downtown to take photos of the Old Mint, I decided to swing by the new Main Library's History Center, and they did have the floorplans. They will be coming in a future project, maybe with a different floorplan annual.
    QuentenMonsenLoopysueRalfGlitchzace66WyvernDakRickoJuanpiand 2 others.
