Royal Scribe
Royal Scribe
Royal Scribe
9,533
Member
3,353
Birthday
February 5, 1968
San Francisco, California
Website
Real Name
Kevin
Mapmaker
16
  • [WIP] Villa Citri (Roman-style villa)
    Here's the third floor.
    The outer walls here are accessed through the spiral staircases in the gatehouse towers and the corner towers. From there, arched doorways secured with metal doors provide access to the parapets of the outer walls. Stairs on these parapets lead to the top of the towers.
    The main villa has two disconnected suites on this floor, nicknamed the Green Apartments and the Blue Apartments because of the color of the tiles. Each is accessed by separate spiral staircases from the second floor. Each has an outer reception room, a private dining/lounge area, an office, and a relatively spacious bedrooms. In previous generations, the Lord and Lady of the manor had separate suites. It is currently occupied by the Dowager Countess of (I forget), who resides in the Caeruleum Residentiae (the blue suite), as it is heated by the hypocaust's flue and the other apartment is not. The other suite is the guest quarters for her son, the current Earl of (I forget) when he visits.
    The upper floor is the bathhouse is currently used for storage.
    LoopysueRickoJuanpiQuentenGabriela
    Okay, here's the second floor again with the courtyards with the same parchment mask as the rest of the outside. There's actually just one mask over the entire thing, but I punched a hole in it with the color key cutout effect. I guess I was thinking "inside v. outside" instead of "this floor v. lower floors." The magenta polygon is now on a COURTYARD layer, so it can be turned on or off depending on which approach is preferred.
    LoopysueMonsenJuanpi
    I'm still toying with the idea of making the legend's text look like it's engraved, but I'm not sure if it shows up well enough?
    I tried it out with Marine Dungeon's brass inlay that I love so much. Here it is with both the red marble on the right side and the black marble on the left (with the original colored text as a comparison). It looks good on the dark marble but only if you're zoomed in.
    And then I tried it again with a goldleaf fill. As much as I love the brass (plus it's native to Marine Dungeons, so it's not added another annual to the mix), the goldleaf may be a little easier to read because it doesn't have the reflected light effect. This one also only really works with the darkest marble.
    Brass Inlay
    Goldleaf
    Thoughts?
    LoopysueQuenten
    Okay, the second floor is mapped and furnished!
    Outside
    1. Muri Magni: Inside the second floor of the outer wall in a 10-foot-wide passageway with arrow slits at regular intervals.
    2. Portae Turres: The gatehouse towers
    3. Turres Anguli: The corner towers
    4. Scalae: Exterior staircases open on one side that lead to the second-floor entrances of the corner towers
    Villa
    5. Portico Roof: The roof of the covered porch
    6. Scalae Graecae: Staircase from the first floor
    7. Scala Spiralis: Spiral stairs leading to the third floor
    8. Cenaculum: The dining room on an upper floor of Roman houses
    9. Heating Caliduct: Hot air from the hypocaust in the basement of the balneae flows through this shaft to heat the floors
    10. Puteus & Puteal: An interior well with unheated water
    11. Lavatrina: Lavatories
    12. Cubiculum: Bedroom
    Balneae
    13. Colonnade Roof: The roof of the colonnade that connects the main villa to the bathhouse
    14. Scalae Graecae: Staircase from the first floor and up to the third floor
    15. Hypocaust Chimney: Exhaust vent for the vast amounts of smoke generated by the hypocaust in the basement
    16. Armorium: Closets
    17. Bibliotheca: The library, including a reading area overlooking the tepidarium pool
    18. Palaestra: An exercise area and prominade
    19. Gymnasium: Exercise equipment
    LoopysueMonsenRickoQuentenRaikoJuanpi
  • Compass Roses
    They are absolutely stunning! These will be a great to have available for map styles that don't come with cartouches (and as a supplement for others that do).
    As a jog for inspiration, if you're open to ideas: sinister/evil (evil sorcerer, lich king/vampire/undead, etc.), fairy tale, swashbuckler/pirates, maybe demihuman-inspired ones (elven, dwarven, halfling, orc, draconic)? Maybe seasonal -- your top one is great for spring and summer vibes, but it would be cool to have autumn and winter options.
    Ricko
