Royal Scribe
Royal Scribe
Royal Scribe
9,531
Member
3,353
Birthday
February 5, 1968
San Francisco, California
Website
Real Name
Kevin
Mapmaker
16
  • Fractal Terrains to CC3+ - Three Approaches
    There were already separate threads seeking advice on the Parchment Maps and Jerion Shading approaches. I wanted to share a little about my technique for the Mike Schley style, including things that I would do differently next time.
    I wanted to have some contours consistent with the other maps, so I opened the Jerion export and copied one of the contour areas onto the Schley map, just where the Jerion contour colors started to turn brown (I think around 5,000 or 7,000 feet in elevation). Playing with a technique that Ralf showed in the Jeriod shading demo, I moved that contour to a contour sheet and changed the fill to the Solid 10 fill. I added Edge Fade, Inner and Transparency effects to that sheet. I then created a second contour sheet with the same effects, and did the same thing with a somewhat higher elevation (I think it was around 11,000 feet in elevation). That worked well. I liked how it gave shading and depth without being too intense like a bevel effect would have done.
    Here's what I did next that I would do differently next time. First, I look an even higher level of elevation and did the same thing. But instead of putting it on a contours sheet with a Solid 10 fill, I put it on a Land Features Hills Background sheet and changed it to the Hills Background fill style. I also added a Transparency effect to that sheet. And then I did the same with an even higher elevation, putting it on a Land Features Mountain Background and changing the fill style to the Mountain Background fill. At this point, the file got massively big. I think it had a lot of nodes to contend with. Next time I try this approach, I might still do the two Solid 10 contour imports, but instead of also importing contour lines for the hills and mountains, I will draw them on using a JPG image of the original export as a rough guide for where to draw them.
  • FT3 Question
    Ralf does demonstrate it at the end of this "Fractal Terrains to Parchment World" tutorial (around the 38 minute mark), using a full world Parchment Map that he had created the week before.
    JackTheMapperJimProflo1
  • Remapping the Forgotten Realms
    I highly recommend the tutorials, too. I spent five years thinking I could learn it just from the PDF manuals, which are great references but I couldn't quite get it from them. Joe Sweeney's "Parrot Island" tutorial really made things click for me. From there, I watched more of Joe's tutorials, and then some of the shorter ProFantasy ones. Remy Monsen created a page describing the video tutorials. I'd start with Learning CC3+ and Campaign Cartographer Concepts, and then fill in with the Quickies to learn specific techniques before moving on to the Live Videos.
    The Live Videos are fantastic, but some of the more recent ones may be a bit advanced for newcomers until they get the hang of the basic fundamentals. I watched one of the more advanced ones when I was first learning, and it was way over my head -- but really great in showing me the power and potential of CC3+. And now that I've grasped the fundamentals, I'm addicted to the Live shows, though I usually have to watch hours later. For me, they're very peaceful. I love seeing how a blank canvass can evolve into a work of art. I've watched the two Forest Trails ones multiple times when I need a soothing, bucolic break in nature.
    JimPSteven Nentwig (Steven!)
  • Sinister Sewers - Style Development Thread (CA207)
    We've been thinking of colors for sewers that are used for their traditional use. But if we start to think of the reasons why a necromancer might need a sewer-type system beneath their lair, or a demon lord, or an archfey, or even dwarves creating subterranean aqueduct, then all sorts of colors make sense: bright water, glowing green goo, rivers of blood, lava...the possibilities are endless.
    LoopysueJimP
