pvernon
pvernon
- pvernon
- 1,104
- Member, Betatester
- 112
- Surveyor
- 2
Reactions
How long have you been using Campaign Cartographer?
Stuck with a Template
Also there stuff on the Common Sheet (shouldn't be any thing there). I would go thru each of the sheets and make sure what is on each is what is supposed to be there. Hide all of the sheets, then show each sheet separately. If something is out of place move it to the correct sheet as you go. Checking the layers the same way could be a good idea as well.
Diagonal Square
Panzer sample thread
[WIP] City of Accordo (Ferraris Style)
Looking at your city it seems to me that it is big enough that I don't think I would put in all the buildings. I would put in the important ones but not all. Then make closeup maps of the areas that need it. So if your party goes to the "Inn of the Old Sign" but there is no combat in the area just put a dot on the map with a label. Does that all make sense?
