pvernon
pvernon
- pvernon
- 1,104
- Member, Betatester
- 112
- Surveyor
- 2
Reactions
Panzer sample thread
Shadowrun Annual?
What do things look like from above?
New Mouse
There is a problem with Win 10, if you do not have a mouse that is win 10 compliant it will double click. I had a nice Logitech mouse that I really liked, then Win 10, I ended up buying a new mouse, solved all of the problems, except that it does not work as well as the old one did before win 10. :(
WIP Commission, Ancient Tombs
Two ways I can think of;
1) trace the contours and just use them as is. Very map like, and may not be what the client had in mind.
2) use the traced contours and more shades of grey to build the gradations. So where you have 3 polygons now ( including the Island base), you would have 6 polygons and 6 shades of grey. I think using the same effects, but some tweaking may be necessary.
