Quenten
Quenten
- Quenten
- 8,062
- Member
- 3,090
- November 29, 1950
- Australia
- Real Name
- Quenten Walker
- Mapmaker
- 16
Reactions
Watabaou Help
The manual for the Watabou City states the need for a SVG to DXF converter.
"Converting SVG to DXF Format.
We now need to convert the SVG format into a vector graphics format that CC3+ can read, for example DXF format (Autodesk’s open interchange format for CAD drawings). Fortunately there are a number of free online converters available for this purpose. I am using CloudConvert, a simple, quick and easy web tool. Simply upload the SVG file you just saved, click “Start Conversion”, then download the resulting DXF file."
Watabaou Help
We need a SVG to DXF converter Jim. The one Ralf suggested only gives separate lines, not polygons anymore; and I have tried two others with no luck.
What I have been doing is export the cities with thin lines only, and definitely no trees. The area by area, picking the outlines of houses, and using Line to Path, and Path to Polygon. It mostly works. You have to get rid of a lot of lines used to delineate areas though. I might do a follow-up tutorial on it. But if Ralf or Monsen can come up with something easier, that would be great.
Community Atlas - Forlorn Archipelago - The Bleakness - Dungeon of the Dragon
Or else, resize the scale bar AFTER you resize everything. And I use Remy's SCALEDRAWING command (not official CC3+ command, unfortunately - it has always worked brilliantly for me, and takes care of bitmap scaling as well.
Here is the bit he wrote about it in his dissertation on scaling. (SCALE MATTERS, May 2018)
The Automatic Option
Because rescaling a map is actually a lot of steps, especially if you need effects and fill rescaling too, I’ve created a CC3+-addon to do all of this automatically, you only need to determine the scale factor.
To use it, download the file from this address, and put the .dll file from the .zip inside your CC3+ installation directory (C:\Program Files (x86)\ProFantasy\CC3Plus by default).
You’ll also need to have the Visual C++ 2017 runtime installed on your computer. You may already have this, but if you don’t, you’ll get an error message when starting CC3+ with this .dll in it’s directory. Download from the official Microsoft download site, you’ll need the 32-bit version (vc_redist.x86.exe)
After installing the .dll and the Visual C++ runtimes (if required), you can run the command by typing SCALEDRAWING on your command line. The command line will then ask for the scale factor, which you can provide either as the number, or the calculation as with the non-visual scale command. Once you hit enter after providing the scale factor, the command will take care of the rest. Note that it doesn’t update the display when done, so simply hit the Zoom Extents button after running the command. The map should look visually identical to what it did before, as this command handles the scaling of entities, effects and fills automatically, only way to see that the command did anything is to measure distances again after running this command (and AFTER hitting Zoom Extents). Because it doesn’t do any screen updates, it should also be lightning fast, but remember, you won’t see the result until you hit Zoom Extents. If you hit Redraw instead, you can easier see the result of the scale operation, because this leave your current zoom intact.
Profantasy's Map-Making Journal » Blog Archive » Scale Matters
A1 Inn and Stable Battlemap
Watabaou Help
