Quenten
Quenten
Quenten
8,066
Member
3,090
Birthday
November 29, 1950
Australia
Real Name
Quenten Walker
Mapmaker
16
  • MY MUNDI IS READY!
    I love the way you combined outside and inside.
    Ricko
  • FT3 to CC3+ as per recent Live Mapping Tutorial
    I was really impressed with this video, as it has made things a lot easier for me to translate FT3 world to s CC3+ style I like. Thanks Ralf.
    In my example below, I have decided to translate a FT3 section to a Pete Fenlon Style (revisited), but I have also used the rivers that were created in the FT3 map.
    Here is the FT3 map:
    Here is the translation to Pete Fenlon, and it was SO easy. Again, thanks Ralf.
    Obviously not completed.
    Here is an insert.
    Royal ScribeLoopysueJimPRickoRalf
  • Egg Hunt!
    Wow, what a fascinating world. Thanks for sharing
    Royal Scribe
  • Very Minor Interface Tweaks
    First: When choosing Shaded Polygon by Edge in the Polygon drop down menu, it is a bit annoying to then have to type in editshading (if you even remember the command) in the command line - could editshading also be part of the dropdown menu?
    Second: When choosing fractal polygon or polygon line, can a drop down menu option (ie right click) be added to edit the fractalise inputs.
    Third: Could drop down menu (right click) on the erase button be added to just erase the top entity of the selection. Sometimes there are unintended duplicates. While I can deal with these by first clicking the top visual edit button, then Del then P, it would be so much quicker if I could just delete the top entity of the selection where I have had accidentally created multiple copies.
    Finally, can the List command produce an output with about double the font size, and also perhaps a bigger window as well.
    These are the most common procedures I use that would help a lot if put as drop down menus.
    Royal ScribeJimP
  • Assistance with Map Overview Export
    I am interested in why you have had so much trouble doing this city, when i have done several cities far larger with less problem. I would be interested in why you have had this problem and I have not - is it because you are using vector symbols rather than pngs? What do other people think.
    Here are the links to two bigger cities I did for the Atlas.
    Browse Maps - Archesyne - ProFantasy Community Atlas (monsen.cc)
    Browse Maps - Torstan - ProFantasy Community Atlas (monsen.cc)
