Quenten
Quenten
Quenten
8,069
Member
3,091
Birthday
November 29, 1950
Australia
Real Name
Quenten Walker
Mapmaker
16
  • Watabou City REVISED (annual 157)
    I have revised the explanatory notes for the coming annual, and am using this town as the example. this is the completed map - well, it will be unless I get comments that I need to take note of.
    LoopysueRoyal ScribeMonsenMapjunkieroflo1LoreleiCalibreJuanpi
    I understand the tedium of making a city with house symbols for thousands of buildings - at least Watabou provides the placement of the buildings. if you use the house tool, rather than symbols, except for a few buildings, then that reduces the labour of scaling, rotating etc. I am already doing that using Darklands city for one of my Watabou cities, which I will show on a thread on the forum later.
    And thousands of buildings is what I did for my extravaganza city, Dun Fingolfin, which is now in the Community Atlas.
    Royal ScribeDon Anderson Jr.
    Here is a map done - took 45 minutes from downloading the SVG to this product - no text of course, but still, a quick town for adventure. And it gave me a chance to test, yet again, the tools I have used.
    LoopysueRoyal ScribeRickoGeorgeJuanpi
    July is the date we are working to.
    Royal ScribeRaiko
    Here is the final draft (repeat, draft - feel free to add suggestions) for the example city for the July Annual.
    I have completed all the drawtools and instructions to my satisfaction - just waiting for @Ralf to return from his well-earned holiday to see what he says. I am also going to add a plain version of the wall and tower buildings, but this will make the drawtool list quite long.
    It has been quite a journey, being able to take the new version of the Medieval City Generator into a form which can be more or less easily transform into a format that CC3+ can use. I was really pleased to be able to add the trees, alleys and even more simple versions of the Coat of Arms to the mix.
    The bitmap resolution still is not totally satisfactory - but if I make it too large, then the result looks strange, and if smaller, even more tiled. Grrr. And finally the hatch symbol for the fields at the top right are too fine, I think - not enough space between them for a city this size, but I am unsure how to scale them so they work better. And also how to get them to show up in the Symbol Fills list. I guess Ralf will help with this on his return.
    I might also do a much smaller settlement, but use the plain style, to see which people prefer.
    This is the first (probably only) annual style I have done, and I am a nervous wreck - haha I really take my hat off to those like Sue who produce such magnificent annuals. Thank you Sue amd Remy for your helpful suggestions - jsut having difficulty with the fill resolution size.
    I forgot to fix the legend as per Remy's suggestion. Rather than redo it just for this correction, i will post the final map when all the suggestions have come in. I want to turn everything in by 3-4th June.
    LoopysueRoyal ScribeTravellerMonsenRickoDon Anderson Jr.RaikoGeorgeJuanpi
