Quenten
Quenten
- Quenten
- 8,062
- Member
- 3,090
- November 29, 1950
- Australia
- Real Name
- Quenten Walker
- Mapmaker
- 16
Reactions
Watabou City REVISED (annual 157)
The example map I will be using for the upcoming revision annual for this style will be based on this city, which I have been asked to do.
I will aim to use all the drawing tools.
I will also go step by step through the process, so you can all comment (and correct) as I go.
And for fun, here is a picture from the JSON export, to show a 3D version. Who knows, perhaps one day, we can work out a method to export the 3D versions to CC3+!!!
Here is a revised version of the Drawtools. so far, they all work with the Change Like Draw Tool command, including the towers and fields, which was not the case in the original watabou annual.
A bit more work needed on the effects to get it all to my satisfaction, but I think the drawing tools are now ready to go.
I guess the next step is to do an example map.
I need to work out how to revise the scaling of the Hatch files, and how to make sure they are imported into the style, so people can access them if they need to alter the dimensions etc
I have used the line style made by Ralf in that video, and am happier with the towers and walls now. Though because the walls are still a line, the crens are still not totally perfect. Not sure how I can turn a 10' wide line into a 10' wide polygon, using a drawing tool.
Not sure why the round tower on the gatehouse at the top didn't show the same as the round tower below - it did in the FCW, but somehow, not in the jpg.
