Quenten
Quenten
- Quenten
- 8,061
- Member
- 3,087
- November 29, 1950
- Australia
- Real Name
- Quenten Walker
- Mapmaker
- 16
Reactions
[WIP] Greco-Roman Inspired Temple
The Cartographer's Vault Humble Bundle
Sinister Sewers - Style Development Thread (CA207)
Forest depictions for large overland map.
Here are seven different depictions of forest that I would like your opinions on as to which is best. It is for a commission I have, and also will be used in my own Ukadarlia project.
If you have other thoughts, that is also welcome, but i really want to know which one you like best, and also the one you like least, even if you don't like any of them.
Each has dense forest in the centre, and woodland at the periphery.
MY MUNDI IS READY!
You can use symbols in area - which i use a lot - you just have to fiddle with the parameters. one thing I have noted is to make sure the default symbol size is appropriate for the map - and it often is not what is set, so you may have to alter that. Furthermore, you can pick from a variety of trees - and even make your own symbol catalogue by renaming some symbols (clone them first) so they have the same name with ascending numbers.
And it is very quick and easy once you get the settings right.
