Quenten
Quenten
- Quenten
- 8,061
- Member
- 3,088
- November 29, 1950
- Australia
- Real Name
- Quenten Walker
- Mapmaker
- 16
Reactions
Problem with combining path
The problem nearly certainly is far too many nodes in the big continent. Either reduce the nodes, or accept that your main continent landmass will be in 2 halves - it will still look the same as if it were one. I had the same trouble with my Myirandios world many years ago.
BTW, the best command to use to reduce nodes without totally destroying the look of your coastline is SIMPLIFY.
Improving my rivers
Info, Count All command.
Watabou City REVISED (annual 157)
The final step is adding all the extra bits and pieces - forests and trees, wetlands, roads and squares and city backgrounds, hills and contours, maybe extra buildings, buildings and towers on top of one another, even a gatehouse to replace the open walls in some places. And text and scale and compass, of course.
Here it is, partly completed.
I have now converted all the IMPORT into the appropriate sheets using the Change Like Draw Tool Command only.
Remember to set the correct Sheet and Layer for each Change like Draw Tool command.
eg Rivers and Seas (Lakes): Sheet WATER/RIVERS, Layer Water/Rivers
Roads and Squares: Sheet ROADS or ROADS PAVED, Layer Roads. Note that Square Paved cannot be used in Change Like Draw Tools since it has a macro attached. I may change this later if I can find a paving that doesn't need alignment.
Parks: Sheet PARKS, Layer Vegetation.
Docks: Sheet DOCKS, Layer Docks
Walls: Sheet WALLS, Layer Walls (Note: I have done away with the City Wall Layer). I am still not happy with the crens for the walls - now they hardly show. I will fix that.
Towers: Sheet TOWERS, Layer Walls. No longer need to draw these without the Change Like Draw Tools command. And it means no guessing as to the size required.
Bridges: Sheet BRIDGES, Layer Bridges
Fields: Sheet FIELDS, Layer Vegetation. The furrows align to how the generator drew the fields. So often, not a very intuitive direction. However, if you want to use the tool directly to draw fields, the tool does align the furrows (which are Hatch symbols) correctly. In the picture below, I have done this with the bottom right hand field.
Buildings: Sheet SYMBOLS BUILDINGS, Layer Buildings, or any of the Building layers you wish to use, eg Bldng (House 1)
I generally advise doing the Buildings last, as you can then Hide all sheets except Import and Symbols Buildings (with the latter being the selected one). This will then show only the buildings you need to convert.
I have also added buildings on top of the Palace, and smaller towers on the towers around the Palace.
Comments and suggestions really welcome.
