Steven Nentwig (Steven!)
1,209
Member
253
Traveler
2
  • Remapping the Forgotten Realms
    I did all the maps from the Ruins of Myth Drannor box set, and as a bonus added the dungeon maps from the 1E AD&D FR Grey Box.
    Also did all the maps from the Ruins of Zhentil Keep box set.
    I'm in the process of updating some of my older FR maps and busy with mapping the Moonsea cities.
    KertDawgEdE
  • Camp at Night [Battle Map]
    First map of the year. I needed a new random encounter map for my online campaign. I didn't make the map too dark because I use it in combination with vtt lighting fx.
    Also made a forest road encounter map a while back in the same style.
    LoopysueQuentenEdEKertDawgRoyal ScribeRyan ThomasMonsenCalibre
  • 2025 Progress
    The year is coming to an end so I figured I'd show off some of the mapping progress I made and share a couple of tips and tricks I learned.
    At the beginning I was somewhat limited in terms of styles and symbol sets but after getting the humble bundle last year I have a lot more options and found my new go-to city style.
    Also loving this retro deckplan style. Perfect for player handouts.
    One of the problems I have is obvious bitmap tiling with large maps. I tried to mask it by layering a different woods bitmap on top using blend mode and scaling it up. There's still some tiling visible but it's not as bad as before, and it still looks good when zoomed in to street level.
    I applied the same bitmap layering trick to my dungeons as well as placing random scatter terrain to add some visual interest. Next I experimented with lighting as I felt my maps looked somewhat flat.
    I experimented some more mixing and matching bitmaps from different styles and got a bit more bold using ambient lighting.
    I hope you folks had an equally productive year and I'd love to see the progress you guys have made.
    Keep on mapping and happy holidays everyone.
    MonsenRoyal ScribeQuentenRyan ThomasJulianDracoszov66MapjunkieAleDRalfLoopysueand 11 others.
  • Rendering Artifacts
    Adding in empty sheets in between didn't work unfortunately, but copying the polygons to a new sheet with the same effects did the trick. Thanks for the tip!
    Royal ScribeQuentenLoopysueWyvern
  • Alternity: Star*Drive deck plan
    I went back and made some more maps for Alternity, this time trying out a different style. I'm planning on using these as player handouts.
    RickoMonsenLoopysueRoyal Scriberoflo1Michael RoehrlWyvernMaidhc O Casainkilma.ard.venomTheIneffableCheeseand 2 others.
