EukalyptusNow
EukalyptusNow
EukalyptusNow
660
Member
1,248
Germany
Surveyor
8
  • The Swamp Convoy - A quick Schley battle map
    Long time no see. Was quite real-life-busy.
    Created this for tonight's Splittermond session. A convoy going to Rattenzwinge has been ambushed by the ratlings living in the Swamp. A small group of ratlings lies in waiting to ambush our heroes, as they investigate...
    The colour of the water indicates dept:
    Brownish = about shin-high
    Light blue = Reaching up to belly-height
    Dark blue = Up to one's head or deeper
    There's a bit of Transparency Acne on the lower right. I've managed to eliminate the rest by playing around with print resolution and anti aliasing settings. Think I'll leave it as it is.
    Detail shot of the central area.
    A larger version is in my gallery.
    Keep having a fine, long weekend! :)
    MonsenLoopysueMichael RoehrlJimPRickoLoreleipablo gonzalezRoyal Scribe
  • Made a city to a friend
    That's an amazing map. And it's got so many things to discover.
    The temples, the cave, the circles of stone, the necropole... 😀
    Also love how you used the "porch front stairs" as stairs to the inner castle / temple gate. Hadn't thought of that.
    RickoJimP
  • Gioiella, a small Serpentine City map
    No. Had to create the ring in a rather elaborate way:
    - Build another land mass using the land mass tools.
    - Copy the settings of the land mass.
    - Manually set a with
    - Draw a ring shape using the circle drawing tool.
    - Open the sheet effects and put a colour key on the land sheet (as topmost effect).
    - Draw cutouts and manually "rough up" the inside of the ring using colour key fractal polygons.
    - Manually draw the coast lines of the new land masses on the coastline sheet.
    There's probably easier ways of doing this (trace command?), but that was the way that came to my mind. Does anyone know an easier method?
    Finally got my players into this magical lagoon city.
    And as always, playing the setting adds more detail. :)
    Added island names and a few features (the painted walls tell the history of the city - in cryptical and sometimes unsettling art. The large main channel is called "the flow/ river of life", because it runs between the temples of life and death - this is also the way, funeral processions go).
    I've also created an in game map of the magical lagoon the city is set in. The outline is circular, since the whole area was magically transferred to the fae realm, when the city founders struck their first pact.
    I'll either add it as a painting in the office of the high fool, or as a small magically painted glass window in the Temple of The Lucky Escape.
    Used Realms of Legend as the main style, with a few bits from Here be Monsters and Waves from Schley Overland.
    Larger versions are in my gallery.
    Have a great Sunday. :)
    Loopysue[Deleted User]JulianDracosWyvernMonsenMapjunkieRalf
  • Lorenzino's Worlds of Wonders - A return to SS4
    Correct - and corrected.
    Also slightly tweaked the shop's shadow, added some magic indoor lights for the shop room and created a manual shadow for the angel.
    Thanks Remy.
    Update: Just noticed I had forgotten the shadows for three of the columns. Fixed this.
    Loopysue[Deleted User]MonsenJimPRicko
