EukalyptusNow
EukalyptusNow
- EukalyptusNow
- 660
- Member
- 1,241
- Germany
- Surveyor
- 8
Reactions
No Flowers Petals with Flowers using Japanese Temples
Ah... In every newly created map, the flower bushes work as intended - can use them from the catalogue and varicolour flowers/ fruit show correctly.
So it looks like @Ralf 's FCS file works as intended.
I'll work around it on my one, currently still "open" map in this style.
Thanks a lot.
Dark Water Monastery - Style mix village scale map
Finished the cavern underneath the monastery.
The four connections to the surface should allow the demon worshipped at the temple to climb up and play cat and mouse with my party. We'll see how it goes.
Think the map looks good but a tad plain - if you have any suggestions for improvement, please advise.
[WIP] Community Atlas - Kumarikandam - Xinxing - Ylangxi City
Very good. The new fields look a lot better, and the intersection is fixed.
Numbers on the map could be a bit more visible (especially 1, 2 and 3), but think they're ok when viewing the map full screen.
However, the colour scheme and transparency effect on the map key look "off" to me. Maybe remove/ change the pinkish transparency background and turn the letters pink to match the actual map?
And there's also still this corner (sorry to red-mark - was the quickest way to point it out).
Something Evil has awakened =O
