EukalyptusNow
EukalyptusNow
EukalyptusNow
660
Member
1,241
Germany
Surveyor
8
  • No Flowers Petals with Flowers using Japanese Temples
    Ah... In every newly created map, the flower bushes work as intended - can use them from the catalogue and varicolour flowers/ fruit show correctly.
    So it looks like @Ralf 's FCS file works as intended.
    I'll work around it on my one, currently still "open" map in this style.
    Thanks a lot.
  • Dark Water Monastery - Style mix village scale map
    Finished the cavern underneath the monastery.
    The four connections to the surface should allow the demon worshipped at the temple to climb up and play cat and mouse with my party. We'll see how it goes.
    Think the map looks good but a tad plain - if you have any suggestions for improvement, please advise.
    LoopysueJimPMonsenRalfRicko HascheQuentenAleD
    Update. Finished the interiors and also updated the original Map to include the few changes that show with the roofs on.
    Will see if I do the water caverns below next.
    [Deleted User]LoopysueJimProflo1MonsenRicko HascheRalfQuentenAleD
  • [WIP] Community Atlas - Kumarikandam - Xinxing - Ylangxi City
    Very good. The new fields look a lot better, and the intersection is fixed.
    Numbers on the map could be a bit more visible (especially 1, 2 and 3), but think they're ok when viewing the map full screen.
    However, the colour scheme and transparency effect on the map key look "off" to me. Maybe remove/ change the pinkish transparency background and turn the letters pink to match the actual map?
    And there's also still this corner (sorry to red-mark - was the quickest way to point it out).
    [Deleted User]JimP
  • Something Evil has awakened =O
    Very nice. Looks like either the mystery-shrouded start or the bload-soaked end of a great adventure.
    Great mix / layering of symbols around the open grave. And now I want more Schley Dungeon Symbols again...
    JimPDon Anderson Jr.Ricko Hasche
