EukalyptusNow
EukalyptusNow
EukalyptusNow
660
Member
1,241
Germany
Surveyor
8
  • The Harvest Moon Motel - a floorplan attempt
    @JulianDracos Kind of both: There are drawing tools and a sheet for road lines (with a slight edge fade effect).
    The "dashed line tool" did not work properly for me, so I drew one dash and copied it, to draw the road middle line.
    For the parking lines, I drew a single line with the tool, then copied them while having the "ortho"-box at the bottom of the creen checked, so they were aligned.
    @DaltonSpence Most of that is included:
    • The Check in Office is at the western side of the building, near the "green carpet"-entrance. You can see the light shining through the counter window in the night version.
    • A room with vending machines, washing machines and dryers is to the South of the Check in Office. The three dark boxes emitting a faint light at night are the vending machines, the light boxes are washing machines and dryers.
    • There's some appliance boxes in the central corridor, but there should be more, and a central heating/ utilities room would make sense - I was a bit puzzled there was none in the original plan.
    • Thanks a lot for pointing out that I had forgotten the heaters...😏 will correct and see what I can do about utilities.
    Update:
    Added heaters, installation in the central corridor and some additional furniture:
    I've also updated the gallery images.
    JimPMythal82
    And here it is. Enjoy your stay.
    Update: Moved the grid sheet so that it is below the "Map Name Sign".
    If you have any other suggestions for improvements, please tell.
    Maidhc O CasainLoopysueMapjunkieJulianDracosLauti
    Wanted to try around with the "modern" floor plans a bit. This is based on a real motel floor plan that we once used for a World of Darkness Game.
    Overall I'm not the biggest fan of the floor plan styles. They could use more symbols and some textures appear to be very low resolution. I ended up rescaling the indoor textures and using Darklands City and Creepy Crypts for some outdoor textures.
    Will try creating a lighted night version next.
    A larger version is in my gallery.
    LoopysueRicko HascheMapjunkieLautiOctorilla
  • A small cave complex for a side quest
    Sounds like a plan.
    If it's now a scaling issue, you can try putting a single colour sheet directly beneath the "Acne"-sheet and see if that fixes the issue where it is.
    EdE
  • Path to the Temple of a Thousand Gates
    Since the in game map for today's adventure contained a few spoilers and since I wanted to do an Empire of the Sun map anyway, I recreated it with a few embellishments:
    The work was fun, but the style could really use some "Japanese style clouds" (if these already exist in the style, please point out where they are so I can have a laugh, too ;-) ).
    A larger version is in my gallery, as usual.
    [Deleted User]WyvernLoopysueJimPMapjunkieMonsenEdEroflo1Ricko HascheGlitchand 2 others.
