Frosty
Frosty
Frosty
160
Member
148
Surveyor
2
  • 1920s Town
    Not sure if this looks better or not but need to move on to work on other things. May come back to this later.
    I was going for a yellow solid line at first thinking of the indi movies. May come back to this and change the line color maybe add and affect to it.
    JimPMaidhc O CasainKit FlemonsLoopysueRickoEukalyptusNow
  • Arkham House Basement
    The Start of my Arkham House Basement. The main room with bookshelves is suppose to be a museum where I will display artifacts the group(s) they have found over time.. and maybe figure out how to link it in Roll20 to actual handout that describes the item. I hope to figure out how to take an image and turn it into a symbol that I can put on the tables or bookshelves.
    RickoLoopysueQuentenJimPTheIneffableCheeseRalfLoreleiLauti
  • Arce Ursi
    I am not 100% happy with this map.. I am still struggling with keeping everything the same scale on a map. But at least this one is better than the last.
    LoopysueRickoEukalyptusNowJimPLautipablo gonzalez
  • Mars Ultor
    The redone map has gone over rather well. The Columns using dynamic lighting look fantastic and give the place a lit but of an eerie feel to it which was perfect. Photos here I used for atmosphere and to describe the ruins on the service at Mars Ultor. I used the modified map for below ground ruins..in what I claimed was an older version of the temple that sunk in early 300 AD.
    Here is a small outside area of the map with dynamic lighting in affect. I think it gives a decent impression of what the players could see. Keep in mind what looks like a shadow here was an area they could not see at all.. so something could always be lurking behind a pillar.
    LoopysueRoyal ScribeQuentenJimPRicko
    Top Floor, stain glass windows do nto fit smoothly with the walls.. not sure what to do about that unless I just go with different windows.
    LoopysueQuentenMonsenLautiCalibreRicko
    Added custom symbol for found artifacts and added them to the basement tables but thinking I may remove them and just use tokens in roll 20. With tokens in Roll20 I can use a macro and API to causes a popup and message in roll20chat that includes a link to a handout on the item in question. Besides I would need to figure out how to export from CC3 with enough detail one could tell what the artifacts are. Example here zoomed in a bit in CC3. Obviously with some of these PNGs I would need to go back and figure out how to remove the backgrounds if I was going to insert them lie this directly on the map. There is a little more detail on the ground floor but I will share once it is closer to being complete again. One thing I am running into is this is a map for 1920 North America and finding symbols for things like Lamps, Coat racks, phones, and decent couches/sofas is near impossible..well that exist with the content I own which is all annuals CD#, CC3, DD3, and two of the symbol sets one being modern if I recall. I did import a few symbols I already had but most were 3D for something I was working on and do not look right. if anyone is aware of a source of 1920 or even more modern symbols I might be able to leverage I am all ears.
    LoopysueJimPRickoLautiDak
  • 1920s Town
    Once I create some things that look halfway good I will post them. And honestly what is important is do the maps in things help your players visualize what your trying to imagine. How historically accurate I think is secondary. :-) I did create this overland journey map but it needs a lot of work to be good.
    However, it still will work as a visual prop in the game.
    I need to find something better to use for the trail and take my time moving the panes etc so they line up. + The map could use a few text labels as what you see in the background is a bitmap of 1920 world map. Due to size etc I am starting to think what I need to do is connect the circular graphic to the trail via a different line and put the text label there it make more room.
    MonsenLoopysueJimPRickoEukalyptusNow
  • Expanding Endless Sea of Ice FR
    I think it is done. I do wish I had a way of making little cave entrances on these cave walls. If anyone has an idea for that or monster nests that look a little less like bird nests I would love to hear it.
    Royal ScribeLoopysueRickoRyan Thomas
  • Forgotten Realms Interactive Atlas repairs.
    Guess who found there Forgotten Realms Atlas this weekend? Now just need to figure out how I am going to connect a CD drive to one of my PC's :-)
    JimPDon Anderson Jr.roflo1
