Glitch
Glitch
Glitch
1,592
Member
808
Surveyor
  • [WIP] Haunted Mansion
    Thanks for posting the fcw files - I learn a lot by taking others work and deconstructing. Great work!!!!!
    Royal Scribe
  • WIP - Largo Cripts
    Started to work on supporting battle maps - beginning with the chapel.
    I used the room tool to create the rough layout and got this artifact, tried it a couple of times and got the same result - any suggestions on what I'm doing wrong?
    Royal Scribe
  • Castle Perilous
    Great thoughts - I usually pencil out my drafts; but I think this has convinced me to start working my drafts out in C3 . This has a double advantage: being able to hand out a rough map to players and more time working in C3 usually means learning more!
    Royal Scribe
  • WIP - Wayward Village and Inn
    Wayward Casino
    Located in the front of the Wayward Inn, the Casino is run by Dapper Dan and order is maintained by Sweetie (Lead Bouncer) and her crew.
    The doors behind the bar lead to the kitchen, beyond that is the Inn’s main dinning room. There are no windows and the only public entrance is the foyer off the street. On either side of the Common Casino are a set of stairs leading to a balcony and the “Rent by Hour” rooms. The Common Casino also has a small stage – currently playing are “Bletcher” Smites (Various Instruments) and Uvaldi (Singer).
    The Casino takes 15% of each pot and charges table fees that range from a few coppers to 5 gold pieces. Games include: Poker, Cheater’s Poker, Whist, Roulette, Various Dice. There is also “Barrel Riding” contests where two opponents face each other standing on the barrel and exchange slaps.
    The Casino is usually well attended with weekends being extremely busy.
    Royal Scribe
    1.      Used Color Key on Grid. What a wonderful solution – I had been playing around trying to find a way. As soon as it was mentioned, I slapped my forehead and shouted “Duh”.
    2.     Moved “Balcony” floor to its own layer, adjusted stairways
    3.     Aligned Text sections.
    4.     Enlarged base drawing – thanks, again a great suggestion
    I use the hex grid since it is intended to be a battle map, and it displays well on our home made tabletop.
    Tomorrow is a travel day, so no more work until Sunday. As always - any comments or suggestions are welcome!!!
    Royal Scribe
    Added blank space filler, used a combination of Select Grid points and knock out for final grid. Think I'm on to the next one, unless anyone spots something else. Thanks All!!!!
    Don Anderson Jr.
  • A small frontier fort....and dead bodies....
    Nice layout - looks like it would make a good run.
    EdE
