EdE
EdE
EdE
557
Member, Betatester
558
Birthday
February 5, 1965
Ohio, USA
Real Name
Ed Elce
Surveyor
5
  • WIP Inside a giant tree
    Thank you all.
    Sue, I am playing with the colorize effect but you are right, this is more clay than wood. Never found anything I really liked but the colorize effect is going to be a favorite
    Wyvern, very interesting idea, my thought was a dryad formed the tunnels, which would entail a nature "growth" as opposed to tunneling which would damage the tree & thus the dryad. In conjuction with jonas' spiral inward idea I think it might work really well. The green carpet is an attempt to convey a slimey moss covering, the whitish pustule in the upper right room is intended to be a coccon.
    Jonasgreenfeather, great idea. Spiralling to the heart of the tree makes for a better layout & more in line with the story. I like the pinch point idea in the passages as well. The party is going to have small, biting spiders crawling all over them once they pass the web room, and slimey moss actively grasping at their feet, it will be help to amp up the tension too... and then there's the wood golems...
    jonasgreenfeather
  • WIP Ryecroft Town
    Thank you JimP
  • WIP Everyone's making Inn's & Taverns - making floor look used / abused
    Yes, it does. Thanks for the feedback Sue.
    Ed
  • One night of fun - A mini dungeon with that ends with a dilema
    Thank you Ricko. I will follow up. I typically use the maps on a VTT that has it's own grid overlay but knowing how to deploy the grid on just the active map will be helpful.
    Ricko
  • I couldn't help myself.
    I'm chuckling but I'd like one space in our collective lives where politics never invades the conversation.... That said, you are missing a volcano bleeding lava in the upper right of the mountain range.....
    Quenten
  • Forest encounter area - Forest trails + SS2A
    Thank you Kevbeck, steal away. I look at a lot of maps others have drawn and I am certain I create very similar content at times either intentionally or not.
    Thank you LoopySue, that was very helpful
    That is likely the issue. My setting sa re below and you are correct about the differences. My anti aliasing is much higher, my size/resolution is smaller and I noticed you don't have the progressive jpeg option active. Using your settings my computer is rendering the jpeg very slowly now but the output is much better.
    My rendering is only 2.98GB, the Fantasy Grounds VTT can accept a file that size without choking on it
    Thank you. That was very helpful. I will check the Tome of Ultimate Mapping more closely for more on this.
  • The Gorgon's Head: A beer hall where gnomes get their own room
    Thank you JimP.
  • Lighting Question
    Thanks JimP. I'm sure it's something really simple that I am missing.
