EdE
EdE
- EdE
- 557
- Member, Betatester
- 558
- February 5, 1965
- Ohio, USA
- Real Name
- Ed Elce
- Surveyor
- 5
Reactions
Lighted Dungeon WIP
Playing with Creepy Crypts
I am creating a night time encounter in a graveyard for a VTT game and LoopySue's Creepy Crypts is turning out to be awesome for the task. I just realized that we never asked for any corpses so I had to raid DD3+ for my dead body. This is WIP, plenty more details to add but I wanted to share and see if there were any suggestions from the community. Map without the shadow effect on is down below
And without the night time effects
Cheers
WIP: An Extra Planar Location A way station in Oblivion
The party has left the dimension! Travel to the resting place of the famed magical sword known as The Darkness in a tomb buried kilometers below the world's surface, requires passage through an exra planar gate. The first step on the journey is a way station in Oblivion where entrance to the tomb is accessed through a through a second gate. But which is the right one?
DD3 Color and Forest Trails with third party magic circles.
WIP A wayside camp on a high road
WIP Everyone's making Inn's & Taverns - making floor look used / abused
Thank you, Wyvern. I appreciate the insights into improving the design of the building. I will take a run at a 2.0 version of this at a later date but for now I have a D&D game to GM this week and I need the map done. I gave in and added windows to the ground floor and nixed the upper story. I'll take these learnings and use them for my next "frontier" Inn. For the moment, I give you the Shaggy Shep Inn and Tap Room. Center of life in the hamlet of Kilmeade.
Cheers.
A cave entrance with Water
WIP Lighted Dungeon
I've been playing and failing at making ligthed dungeons for quite some time. The secret is to not have a Directional Wall Shadow effect on the walls of your rooms that you apply the Wall Shadow, Point Light Setup and Final effects to. Must admit, I did not see anything specific about that in the Tome but I resorted to shutting effects off one at a time and.... BINGO...
Still needs quite a bit of work but I can FINALLY make a lighted dungeon....
WIP A Murder Scene
I am trying to simulate sunlight shining through a window, specifically the window on the left wall and the one on the front wall to the right. I changed the color on the Wall Shadow, Directional effect to a bright yellow and used the Global Sun setting so it matches the shadows cast by the wall. I added a stronger shadow to the sack just below the left window and the cauldron to the right of the front window. Does it work or am I just messing up the map? Any thoughts are appreciated.
A small cave complex for a side quest
Experimenting with SS2 again for a small cave complex. Need to work on exporting the maps, things like the worn path in the cave floor and the water foam come out much darker on export as a jpeg. The ground cover gets rather blurred as well.
Need to dig up the sheet acne solution as well for the filler.
The rising water has trapped the leader of a goblin hunting party in the cave because he's slowly becoming a vampire spawn. The goblin tribe asks our intrepid heros to lay him to rest.... what could possibly go wrong?
