9,985
Member, ProFantasy
9,863
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • The Lakes of Michigami (Jerry's Map) - WIP thread
    You're awesome, Jerry. Thank you for letting me have a go with your map like this :)
    GThiel
  • Small Town of Fulnet
    Ralf generates a grid and index of place names next to the map in this video here.
    This link is direct to the point where he starts that process, though if you have time to sit and watch from the beginning it is a nice overall learning experience.
    [Deleted User]
    After thinking about this for some time I think I might change style to use Ancient Realms style from the 2014 Cartographer's Annual. This style has several qualities that make it suitable for small scale mapping of very large areas like this one. Firstly there is a good collection of attractive mountains and hills, the fills are about the same colour and tone as the fills in your original map, Jerry, the woodlands are a fill rather than millions of very tiny individual tree symbols, and there are those very attractive circular points of interest markers that will be really handy for things like the salt mine, where they would be too small to show as other than a dot in other styles.
    I know you won't see this for a while, so I will mock up a small section of the map for you.
    GThiel
    Something a bit like this?
    I took the lazy option with the coastline and ran TRACED on the mask from the heightmap so that it matched the bitmap I'm using of the entire area as a guide for where to put the mountains and hills, but I think the Old Mission Peninsula is more of an island than a peninsula the way it appears in the original map. I will have a closer look at that one but this is just a taster to see if you like the style for the map.
    EDIT: I think I was working on this comment before you posted yours, so didn't see it till I'd done my own.
    No - I'm not sick of it. I'm quite enjoying myself. I haven't used this style before.
    Original comment below
    Ok. I've only done a bit more and some tweaking on effects, but I want to pause and see if you feel this is going the right way.
    Just to the south of this green area is what appears on the real world map to be an extensive low plateau with mixed farming and forest. There are loads of kettle lakes here. In the real world its all very green and lush. That's all I can make out from the various maps I have.
    Do you want me to do something similar, or go for Mordor? A desert would be somewhat out of place because of the lakes. Maybe just a straightforward moorland?
  • Edge Fade and SS4/5
    It didn't work on this one. But I got it to work with a backing sheet instead. For some reason the usual purple didn't do the trick. Sometimes you have to try different colours.
    Atrivion
    You're welcome :)
    This is one of the only ways for now.
    There are possible solutions in the pipeline, but they are quite a long way ahead just yet.
    Atrivion
  • [wip] d&d Basic/Expert set of maps
    Interesting but otherwise useless fact: There may be a discrepancy between what Americans call mold and what Brits call mould. To me, a mould is never green, being more like a slime mould or fungus. Anything green is algae, lichen or moss.
    [Deleted User]
  • Tangram Heightmapper
    I've no idea if anyone else has already shared a link to this site, but if you are looking for heightmaps to use in Wilbur or FT3 to generate real world relief shade maps this might seem to be a good place.
    The only drawback is the Mercator projection, which grossly distorts anything in the extreme north and south.
    [Deleted User]Raiko
  • WIP Morwara (Erdan Worlds of Wonder style)
    That's why I suggested it, but the side effect is that Medio won't be able to take land feature textures and shading right up to the edge of it like they are right now.
    Maidhc O Casain
