- Loopysue
- 9,978
- Member, ProFantasy
- 9,861
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
        How to KernDo you have a screen shot of the fonts you mean and the bad kerning? Some fonts don't behave well when placed as curved text. I believe font kerning is controlled by Windows (even in CC3) based on information built into the font itself. If you are having issues with straight text problems can arise because the font is badly designed - as many of the free ones tend to be these days. In those cases the only solution is to explode the text and move the letters individually wherever it is particularly bad.
        World Map
        What games do you use ProFantasy to create maps for?
        How to light caves without entire outside being darkIf you have the Tome of Ultimate Mapping, lighting is covered from page 279 under the title "Lighted Dungeons" Alternatively, there are a couple of Live Mapping sessions you might be interested in here: https://www.youtube.com/watch?v=XuzRZFJl53M https://www.youtube.com/watch?v=TQKEswmn10A At the present time there isn't a way of transferring the settings themselves to VTTs. Any lighting you add to your CC3 map will show in the exported image and be fixed as part of the image.
        Project Spectrum - Part 2Thank you, Joe :) That's really helpful. Unfortunately, if such things are possible in Gaea I haven't found them just yet, but I will have a look. I am just in the middle of adjusting the models to have flatter tops at least, even if I can't seem to control the steepness of the slopes. This is shorter than they appear in Blender because I exaggerate the vertical scale in Blender.
        Live Mapping: Hilltop Fort 1Hi everyone :D In this week's live mapping session Ralf will be starting a new project: combining dungeon and city assets to build a hilltop fort. Join us live on YouTube here to be part of the chat: https://www.youtube.com/watch?v=Zc89lO0ODAc You can watch it there later if you miss the stream, or maybe right here on the forum if you don't like YouTube:
        Live Mapping - Hilltop Fort 2Hi everyone! :D In this week's live mapping session Ralf will be continuing his hilltop fort project by adding the details of the courtyard and buildings on top of the hill. Join us in the chat of the live session here on YouTube: https://www.youtube.com/watch?v=xDIhBc69LCc Or if you prefer you can watch it right here: Looking forward to seeing you all live :) If you missed the first part you can watch it again here on YouTube: https://www.youtube.com/watch?v=Zc89lO0ODAc
        Live Mapping - Hilltop Fortress (3)Hi Everyone! :D In this week's live mapping session Ralf will be returning to the Hilltop Fortress map for a third and final time to finish up the surrounding swamp and add finishing touches. He will also be taking a look at preparing the map for use as a battle map in a virtual tabletop setting. Come along and join in the chat on YouTube here: https://www.youtube.com/watch?v=63sds-xnzow Or watch it here on the forum if you prefer.
        Arce UrsiThat old hatched stone fill seems to be stuck in the DD3 repertoire, but there are other alternatives around. If you are looking for something reddish you could use one of the Dirt fills instead, or maybe the "Stone Lava Cooled" and a sheet effect to change it's colour to something more reddish. If you have other add ons there's no reason you can't use a fill from one of them if there's one you would prefer. How you do that is use Insert File in the Draw menu and pick a pre-prepared blank map of that style (or the actual template file .FSC) and press ESC just before clicking to place it in your map. That will import just the fills for that style which you can then use in your map.
        Horizontal lines between walls when tracingThese are caused by the nodes being too close together in a heavily fractalised polygon. Notice how they occur on the fractalised parts of the object rather than the simple straight line sections. Undo or delete the new wall tracing and use the keyboard command SIMPLIFY, set a distance of about 0.25 (if that is a 5ft snap grid I can see), on the floor polygon. What this will do is remove any node that is only 0.25 feet or less in distance away from it's neighbour. Then either trace the wall shape again, or copy that polygon onto the WALLS sheet and hide the FLOORS sheet to change the properties on the WALLS sheet to create the new wall.
