9,977
Member, ProFantasy
9,859
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Black Friday sale now on - 50% off.
    The sale is on...
    Here's your chance to get whatever you haven't already got at half price :)
    JimPDaishoChikaraWyvern
  • How do I get my new maps onto Roll 20?
    Ralf did a Live Mapping session on this just last week here:
    quirky_cartographerChr9s
  • Live Mapping: Tagkrammer Isometric (December Annual)
    Hi Everyone :)
    Tomorrow's Live Stream will cover the use of the newest issue of this year's Cartographer's Annual - a rather gorgeous looking new isometric dungeon style called Tagkrammer Isometric.
    You are invited to come along and join in the fun! :)
    Click the link above and book your reminder on YouTube.
    TheschabiWyvern
  • Why won't the houses change color?
    No it's not a bug. Whether you can change the colour of a house or not depends on what kind of house it is. If you do it to one that has been placed as a varicolour symbol it will work. If not, it won't.
    Maidhc O CasainDaishoChikara
  • Q on Copywrite & Licence
    What Simon Rogers says on this thread is key to your request about the tokens in particular. Simon is our Managing Director, so whatever he says on the matter is the final word.
    Using DD/CC symbols in Roll20 as tokens instead of map symbols — ProFantasy Community Forum
    gameleaperDaishoChikara
  • Review by Technical RPG
    Hi Everyone! :)
    I thought you might like to see the latest review on Campaign Cartographer. This one was done by Technical RPG.
    Thank you very much, Technical RPG :)
    [Deleted User]MonsenWyvern
  • Banners
    I decided against buying font creating software since it would probably take too much of my time ;)
    (I would get hooked on it and not be able to give up)
    WyvernJimP[Deleted User]
  • Cannot figure out how I broke the sheet effects - they won't show up
    Your effects aren't broken. They are just scaled really tiny - so tiny you can't even see them.
    I've just been through the whole set and discovered that you have them all set to Percent of Drawing Extents Width as the Effect Units. This means that whatever figure you had in the Edge Width box (these were also really tiny before I started on the map) is only that percentage of the map width.
    I've changed them all to Map Units and given them about 10 map units Edge Fade Inner. I've also moved that piece of scrubland fill to the TERRAIN DESERT sheet because it was on the same sheet as the grassland behind it. That was why it wouldn't edge fade.
    You will probably still need to adjust them all to suit your taste, but at least you are on the right track now.
    To edit a sheet effect you need to pick the sheet in the list on the left and then pick the effect you want to edit and click the Edit button on the right.
    GreyhSeermike robel
  • [WIP] DOTR The End of Castle Wittgenstein
    Wall tool:
    The wall tool is a line drawing tool and doesn't join into a closed polygon. A wall is a line with a width. Conversely, the room drawing tool automatically draws a closed polygon wall (which is rendered hollow by the line width) because it doesn't know where you want the door to be, or even if you want a door.
    The bridge symbols meet at the highest resolution. There are 4 images of each symbol in a graded set of resolutions to speed up the zooming process, and where they are fuzzy-edged pixel images sitting on a precision vector reference grid they can appear to have gaps between them at lower resolutions. If you have issues with this it may be necessary to draw another line of them off the map somewhere initially using the snap grid so they are perfectly horizontal or vertical, and jink them closer together by hand. Then the string of bridge bits can either be grouped and moved, or just moved to position on the map.
    1) Textures aren't aligned unless they are made to align, and you can only do that with a filled polygon, not a wall. Happily, your floor is a filled polygon. Hide all sheets but the floors and right click the Polygon button on the right toolbar. Click the floor on one of its long sides. The fill will align to that side, but it will also shade like a pitched roof. To get rid of this you need to type EDITSHADING on your keyboard and hit the Enter key. This is a command you have just given CC3. Check the command line at the bottom of the window and see that you are being asked for the entity to be edited. Pick the floor and then in the dialog that appears check the little box called "Shade Only Copy" and OK.
    You should end up with something like this. Here I have shown the 2 steps from left to right.
    2) Before you place the symbols, but while you have them on the crosshairs ready to paste, right click your mouse and then click the Set normal button and the More button and see if that works better for scale. The stairs align perfectly with the snap grid for me.
    3) The interior wall is a symbol, not a fill. I rarely use them at all because they don't match the fills that well. I usually use thinner regular walls drawn with the wall drawing tools, or I draw the entire building in these interior walls.
    I think I got everything there?
    MorrgansMattyEH
  • Grimdark Fantasy (renamed "Darklands") - development thread
    @Monsen Thanks Remy :) Your most recent comment is clearer than all of mine put together. It's not an exact science and pretty difficult to describe with great clarity. The arrangement varies depending on the artist. Because I am also employed part time by Profantasy as a Cartographer and Community Assistant (The latter part of that chiefly on FB where experts are a little thinner on the ground than here on the forum) it is sometimes the case that mappers think I have some kind of control over events. That is just plain wrong, though. I am an artist, and that is all I am. I can make suggestions, point to other promising artists, and offer the things I'm working on right now - just like anyone else can, but while PF are extremely good at listening and fortunately for me seem to like quite a lot of the things I do myself, I never make any of the actual decisions about what comes next or what the annual content should be.
    @Wyvern Yes, having gathered the information I've been given both here and over on the FB Group I can see that I have been a bit confused about what Grimdark really is. There are some incredibly fuzzy edges to the whole description, and parts where it almost seems to cross over with what, at other times, has been described to me as Steampunk, or which seems to make Grimdark seem to be a horror version of Steampunk. That's ok. I can do that. I just hope everyone is ready for the darker shades of Mouse!
    [Deleted User]JimPWyvern
