- Loopysue
- 9,966
- Member, ProFantasy
- 9,852
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Issue with beach on Spectrum Overland
It's possible the beach isn't wide enough to go completely under the faded edge of the grass. Try editing the EFI on the grass sheet to make the faded edge narrower. The alternative is to use the node edit tool|CC2DYNEDIT| to move the nodes of the inner side of the beach polygon further under the grass.
The nodes aren't visible in CC, so it's a case of clicking with the node edit tool on the inner edge of the beach poly until you grab one. You then move it by dragging the mouse and then click to reposition it. On to the next node... and so on.
[WIP] Lumadair - Hand-Drawn Fantasy (CA221)
apr cc3 plus update?
Unfortunately Mike didn't have time to do one for April.
If you want to check what's available and what's not at any point in time, the record for 2025 is kept in this blog here: https://www.profantasy.com/monthly/2025-monthlies-content.asp
Flooring Maps
Live Mapping: Hand-drawn Fantasy
Live Mapping: Villages of Schley *CANCELLED*
building symbols from Satellite Cities
Have you got any other city styles you can use?
@Royal Scribe I tried that. It wasn't. Nothing seems to prevent it, or cure it.
By the way, Helen, I'm not saying don't report it to TS - just that the answer may take a bit longer than usual.
Changing properties on a sheet that has cut through bits
Because those bits have been cut out on the water sheet they no longer exist to have properties changed on that sheet. If you want to change what you see through that hole you will need to modify the terrain you can see on the sheets that are revealed by those holes, and not the holes themselves.
What changes to you need to make to the islands?
So the islands are vanishing?
When you change the properties of the water you are also changing the properties of the magenta cut-outs. They need to remain unchanged.
Try starting from the state of your first screen shot and change the ocean again without picking the islands, or carefully deselecting them so they remain unchanged.
Or, if you have already changed everything to the other water fill, try picking the islands only and changing them back to magenta polygons using Change Properties.
