9,966
Member, ProFantasy
9,852
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Missing Fill and Castles Failure
    @Royal Scribe Yes. But use it when you are certain the map is finished.
    Royal Scribe
  • shadows in a top-down cave
    Well, thanks Don, but I think we should wait to see if I got the right end of the stick here ;)
    Don Anderson Jr.
  • Combine Path causing crash
    This may or may not have anything to do with the problem, but as I worked along that red line I discovered a piece that was duplicated. The only difference was the entity tag number, so I used that to delete the first and shorter one.
    I will stop here because I can see that Don has commented before I really got going.
    EDIT: I wasn't having any trouble all the way along that red line myself, until I got to that duplicated section.
    EDIT2: One thing that strikes me is that you mention using D or return to finish the command. You don't need to do that with Combine Paths. Just right click once when you finish adding all the pieces together. The only extra thing you need to do is if you hit a line that's the wrong way around and have to switch it's direction using F or S.
    EDIT3: I am now very curious to see if you can join thse lines together, knowing what you do now about the way to complete the command, and with the awkward duplicate part removed. If you still can't join things let me know.
    Don Anderson Jr.
    You don't need to press enter. Just right click. That ends the command.
    This is what the Tome says about using Combine Paths:
    Don Anderson Jr.
  • Playing Card County Maps
    I wonder if they would sell, if any of us made a new set of the counties of England and Wales using one of these custom playing card printing sites mentioned by Taustinoc.
    Royal Scribe
    I really need to see the FCW once you've had a go at setting up the lights. I can't see what the problem is without it. I really don't understand what you mean about the yellow wall thing. I can see there is a yellow wall, but I don't understand what you are asking for.
    Don Anderson Jr.
  • Live Mapping: Black and White Fantasy
    Thanks very much Ralf :)
    Don Anderson Jr.
  • Help with snapping symbols to hex grid
    Looking at the way the symbol is misaligned it appears to be too big - overlapping equally on 3 sides.
    Get another symbol on your crosshairs and then right click. You will see a dialog there. Click the Set Normal button and ok. I'm hoping that should give you proper alignment.
    Royal Scribe
  • Draw Hex or Square Overlay won't label bottom row...
    Does your map have a SCREEN sheet with a thick white border polygon on it? If it does, move that sheet to the bottom of the sheet list one up from any MAP FRAME or MAP BORDER sheet you have there, so that it covers the extra grid.
    ubai
  • [WIP] Villa Citri (Roman-style villa)
    Oh you mean that none of those 4 rooftops pieces are joined in any way? In that case it now makes sense :)
    Royal Scribe
