- Loopysue
- 9,966
- Member, ProFantasy
- 9,852
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Birdseye Continental - style development thread
Best approaches for tree shadows?
@ScottA - Oh that was a ring of mapped symbols. I was checking the map file worked from all angles and made a circular array of the same mountain ridge symbol. The symbols do some pretty experimental things as far as having fades all around, which is never done in a house symbol, and sometimes do unexpected things. I will have to check each and every mapped symbol the same way so you don't get any weird effects just by rotating one a little bit.
I will make a crater symbol.
@Don Anderson Jr. - Unless you count tundra as a kind of desert itself? How is a desert defined? Extreme dry? Extreme heat/cold? Anywhere the plants and animals have a hard time?
Question about CA143 Asian Town "well" symbol
Vignette in CC3
Another way of doing something similar (if you want a rectangular vignette, for example), is to cover the entire map in a polygon and use an EFI turned inside out (100% opacity on the outside, and zero opacity on the inside), then a Blend Mode to control opacity and how the vignette works with the map.
Dragon sheet
