- Loopysue
- 9,966
- Member, ProFantasy
- 9,852
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Live Mapping: Ancient Realms Revisited
Can't Export this to JPEG
- Type SIMPLIFY and hit Return
- Look at the command line
- If it's some other figure hit the zero and Return.
- Hit return if you haven't already
- And then select the path or straight polygon you want to simplify. The action will be immediate.
Oh look at that! I bet Wyvern has beaten me to it while I was trying to work out how to make the paragraph numbering go right.
Birdseye Continental - style development thread
Delete range of Entity Tags.
Fractal Terrain 3 landmass question
This is only going to work for you if you are only using FT3 to get a decent shape and coastline...
Try visualising the oceans as the land masses.
I have extracted quite a few decent coastline patterns from FT3 by turning the land into the sea, and vice versa. Its not something you can do in the software (I don't think), but once you get your eye in tune with the idea you should find a few more appetizing outlines
Cosmographer: select all icons based on currently selected icon?
What are your placeholders? Are they symbols, or polygons?
A particular symbol can be deleted using the Symbol Manager in the Symbols menu. Open the manager, pick the symbol you want to delete, and hit the delete button. That will remove all instances of the symbol from your map.
If your placeholders are polygons and are all on a unique sheet or layer you can hide all other sheets or layers and delete them en masse by box selecting with the delete tool.
If your placeholders aren't on a separate sheet or layer, you might have to use one of the many select options available when you pick delete and then right click in the map area.
ALPHA BLUR question
After Day's of Watching Videos
