- Loopysue
- 9,970
- Member, ProFantasy
- 9,853
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Questions about Blueprints (SS3)
If all the symbols are massive to the same extent it may be time to check the size of your map and make sure you have it correct to the scale of 1 foot = 1 map unit, or one metre = 1 map unit.
With a style like this one it is easier to make your own new symbols, such as dimensions, by drawing the first one and making a symbol of it. However, if they are all going to be different non-standard lengths you might want to draw them as lines in the map.
Sinister Sewers - Style Development Thread (CA207)
Creating weather tables using Fractal Terrains data?
MY MUNDI IS READY!
Understanding Fog of War Effects
Have you followed the video or done your own thing?
If you followed the video, when you added the Wall Shadow, Point Light Finalize sheet effect there was an option to pick an alternative colour for the shadow. In the video Ralf picks a dark blue shade instead of black. At around 9.19 minutes in that video Ralf then turns the shadow transparency up to 50 percent the The sun settings, which you can get to by right clicking the hourglass on the left and picking Global Sun.
Have you done it that way, or a different way?
Do I have to use FaceBook to access community content?
Create maps with my own graphic elements?
If you don't need to do anything more complicated than what you just described in your last comment, Remy (Monsen) is right. There should be enough information in the User Manual.
The Tome would only be necessary if you wanted to make symbols that were considerably more complicated than that.
The User Manual gives you the basics. The Tome provides the masterclass.
