9,975
Member, ProFantasy
9,855
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Color key isn't working again
    No need to apologise!
    I hope you are feeling a lot better now :)
  • Auto generate maps by standardized input files
    Hi Florian :)
    We don't currently have a random land mass generator built into CC3, but if you have Fractal Terrains you can generate an infinite number of worlds and export them, or parts of them, as CC3 maps. That lays down the coastline and contours but you still have to add the fills and symbols yourself in the CC3 map.
    We have a simple random city generator that comes with CD3, and you can also import data from Watabou random city generator to CC3 and use it to generate your own city map, whether you just trace the image or get a more direct result. The process is described in the January issue of the 2020 Cartographer's Annual, which also provides a style to use so that you can realise your Watabou cities fairly quickly.
    We don't currently have a random dungeon generator, but you can import images from any other random dungeon generator to use as a guide to draw your own in CC3.
    Florian Ostermeier
    If you are looking for a random city generator that can do all of that try the Watabou one here. This is the generator I mentioned in my comment above. You could either print them directly from the Watabou page or use them as base maps in CC3. The 2020 annual would be a good buy if you decided to do that.
    Unfortunately, towns and cities do take a long time to map because they have a lot more detail than overland maps and cover a much larger area than a dungeon map.
    Florian Ostermeier
    Thx, so you suggest to create the automated part with watabu and then add more styling and features with CC3+, did i get that right?
    Yes, that's right. Watabou could give you the basic map and then you could either insert the bitmap export from Watabou into a city map of your chosen style in CC3, or get hold of the 2020 Cartographer's Annual and use the January "Watabou City" which provides full instructions on importing the city directly in a usable state to CC3 and the mapping style to work with it.
    Florian Ostermeier
  • Blending with background not working as (I expect?) it should
    You will almost certainly do better if you don't use the parchment background, but at the same time sheet effects will be applied to the dashes themselves rather than the edges of the polygon, so you may need to make the background white. That will work if your blend mode is set to multiply, as the white will vanish.
    il mietitore
  • Question for loopysue-Sue Daniel
    Hello rosemarieklien :)
    Julian has already provided the link to the blog breakdown I did of that map. Thanks Julian.
    If you have any more questions just ask away here.
  • Do any styles have East European Symbols?
    There are onion domes in the City Domes issue of the 2018 annual if you want domes to add to other styles. They're based on Saint Basil's Cathedral in Moscow. There are also plainer onion domes from other East European churches in that set.
    The rooftops are pretty complex, but if you want to make complex roof shapes the House tool is your friend. It depends on how much detail you want to get into and how much time you want to spend on each building.
    JulianDracos
  • Live Mapping: 1930s Floorplans
    30 minute shout :)
  • lines that don't delete
    You're welcome :)
    It might be worth considering if you might be using just a little too much detail generally if you end up having to use SIMPLIFY all the time to resolve these line glitches.
  • Live Mapping: E Prybylski Watercolour
    Hi Everyone! :D
    In tomorrow's Live Mapping session Ralf will be taking a look at April's beautiful new overland style by Ellis Prybylski.
    Come and join us on YouTube here: https://www.youtube.com/watch?v=H2jROIqbQLw
    Or you can watch it on the forum here:
