- Loopysue
- 9,982
- Member, ProFantasy
- 9,863
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
A small village
Thank you! A friend of mine is really good at planning and writing (DMing).
Yes, this one is missing. Though now I'm obliged to add it in the 2nd revision, when my second group will start this adventure. :)
My goodness! 2 groups! You really are quite an enthusiast. I hope your players appreciate the care you take with your maps :)
weird line
Cowpens Battlefield
Great work, Mike :)
Though I am surprised about the aiming!
A dusting of snow is a really tricky thing - especially with this kind of map where its more about accuracy and altitude than artistic impression. Do you really need to partially obliterate the important information?
But if it's important maybe find a patchy snow fill and use it on a sheet with quite a strong transparency effect on it? Difficult to know what to suggest.
WIP, suggestions please
It certainly looks like it should be visible.
Can you see the text on your cursor just before you place it? The only other thing I can think is that the text is there but incredibly small. If you think that might be the problem check the size of the font in Text Properties. Sometimes, and for reasons I'm not sure I understand, the text can start off really tiny.
Free symbol pack - Tentacles
WIP - Tomb of Shadows
Moving objects in front of or behind in same sheet.
I was able to replicate this issue, but only when I added the trees after I had already added the smoke.
The easiest solution is to delete the smoke and re-add it, or to move the smoke to a new sheet above the rest of the symbols. Perhaps calls it SYMBOLS Smoke.
I'm not sure if this is what would technically be called a bug, or intentional behaviour, so I will report it for you.
Made a city to a friend
