- Loopysue
- 9,976
- Member, ProFantasy
- 9,857
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Community Atlas: Dendorlig Hall - A Sort-Of D23 Dungeon for Nibirum
And another small map, this time in SS2 / CSUAC2
Live Mapping: Realms of Legend
Hi everyone! :D
In tomorrow's Live Mapping session Ralf will be showcaseing an older but still very beautiful overland style by TJ Vandel: Realms of Legend.
Watch it right here:
Or come join us on YouTube here: https://www.youtube.com/watch?v=VAfhalzyQLA
Winter Trail Project
WIP - Isometric desert temple
New Commission. Ghorfar
Dialogue Concerning two river systems
They weren't loading to start with, but now they appear to be ok.
@CeeJæy A method you might not have tried is to draw the river as a line, and then cut it into sections along it's length and use Change Properties to gradually reduce the width towards the source. It takes a little time to do if you have lots of rivers but the effect is genearally well worth it. The more sections you cut it into the more gradually you can change the line width and the smoother the outcome.
Doors going on Symbol Definition Layer
Hello Thiles :)
The SYMBOL DEFINITION layer is the one that holds all the information for all the symbols. If you hide it all the symbols will disappear, so it is best just to leave it well alone.
Use List in the Info menu and you will see that the door is listed in the blue box that appears as being on the layer you have specified.
Incidentally, while we are discussing layers, it doesn't really make much difference what layer a symbol is on for most of the time. It is the sheets that affect the order in which things are drawn, and the sheets that hold the effects that are applied to them like shadows and glows. Layers are more a kind of grouping system.
Most entities, whether symbol, wall or fill, will go to the correct sheet and layer on placement. The important ones if you are drawing a dungeon map is to leave the walls on the WALLS layer and the floors on the FLOORS layer, or the door and window cutting symbols won't work properly.
