- Loopysue
- 9,986
- Member, ProFantasy
- 9,863
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
[WIP] Bā Dà Chéng Shì
Community Atlas - Forlorn Archipelago - Fisher Isle, several villages and surrounding areas
Forest Trail project - part 1
I'm not entirely happy with the dirt patches and may modify them to be less like large grit, but they are already little more than dots in the original graphic. Maybe I will dot a larger patch and then reduce it in size...
Mushrooms are a great idea. This time I think more realistic ones. The Creepy Crypt ones were really huge!
[WIP] August Mapping Competition -- The Blue Rose Tavern
It's looking really great :)
You could still use FLOORPLANADD. If the map itself is a different size you can use Resize Drawing Area in the Draw menu to correct that so that it matches the other levels. If the layout is the wrong size you could delete it and copy and paste from another floor using the map origin as the copy and paste origin. Then, even if you only want the walls from the other level's map, or the walls and the stairs and dividing walls, you have a head start on things.
Can't TAB through some Symbols - Creepy Crypt
[WIP] August Mapping Competition -- Vertshusen Distillery
That looks better with the coal on the ground :)
I think you might need to change your Maximum Pixels Per Pass, looking at those bands you have there on the last render.
Type EXPORTSETMPPP and hit enter. Check the number shown in the command line. The default is 4000000 (4 million). Type 40000000 (40 million) and hit enter again. Next time you render that should get rid of those horizontal stripes.
